Differences
en:uhsdr_dev:toolchain [02.02.2018 07:34] – df9ts_user | en:uhsdr_dev:toolchain [06.02.2018 23:03] – df9ts_user | ||
Line 1: | Line 1: | ||
{{tag> | {{tag> | ||
===== UHSDR development - toolchain for Debian ===== | ===== UHSDR development - toolchain for Debian ===== | ||
Line 11: | Line 11: | ||
* Eclipse | * Eclipse | ||
* Check installation with test project | * Check installation with test project | ||
- | Cloning UHSDR from Github, compiling and running (later) | ||
=== GNU ARM toolchain for Linux === | === GNU ARM toolchain for Linux === | ||
See [[https:// | See [[https:// | ||
=== Install Arm toolchain for Linux === | === Install Arm toolchain for Linux === | ||
- | * Download the latest Linux install tarball file from ARMDeveloper | + | * Download the latest Linux install tarball file from ARMDeveloper |
* Link to download: https:// | * Link to download: https:// | ||
* Assuming downloaded file is in / | * Assuming downloaded file is in / | ||
Line 27: | Line 24: | ||
$ mkdir -p ${HOME}/opt | $ mkdir -p ${HOME}/opt | ||
$ cd ${HOME}/opt | $ cd ${HOME}/opt | ||
- | $ tar xjf ~/ | + | $ tar xjf ~/ |
- | $ chmod -R -w / | + | $ chmod -R -w / |
* Test if the compiler is functional; use the actual install path: | * Test if the compiler is functional; use the actual install path: | ||
* Output should be like this: | * Output should be like this: | ||
- | arm-none-eabi-gcc-6.3.1 (GNU Tools for ARM Embedded Processors | + | arm-none-eabi-gcc-7.2.1 (GNU Tools for Arm Embedded Processors |
- | Copyright (C) 2016 Free Software Foundation, Inc. | + | Copyright (C) 2017 Free Software Foundation, Inc. |
This is free software; see the source for copying conditions. | This is free software; see the source for copying conditions. | ||
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. | warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. | ||
Line 44: | Line 41: | ||
=== GDB - GNU Debugger & OpenOCD === | === GDB - GNU Debugger & OpenOCD === | ||
- | GDB 7.12 distributed with the initial GCC 6.2 (gcc-arm-none-eabi-6_2-2016q4-20161216) has several issues (crashes on macOS and is incompatible with Neon.2). | + | Check that GDB is installed in your Linux distribution by entering |
- | The recommendation is to use the update version gcc-arm-none-eabi-6-2017-q1-update, | + | |
- | === Install OpenOCD === | + | |
- | * See [[https:// | + | |
- | * Download from [[https:// | + | |
- | * Latest version is gnu-mcu-eclipse-openocd-0.10.0-5-20171110-1117-debian64.tgz | + | |
- | $ sudo mkdir -p / | + | $ gdb |
- | $ cd / | + | |
- | $ tar xvf / | + | |
- | * Test installation: | + | The output should look like this: |
- | $ /opt/ | + | GNU gdb (Debian 7.12-6+b1) 7.12.0.20161007-git |
+ | Copyright (C) 2016 Free Software Foundation, Inc. | ||
+ | License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html> | ||
- | | + | If missing install with |
+ | apt-get install gdb | ||
+ | * This leads e.g. to [[https:// | ||
+ | Installation: | ||
+ | $ cd ${HOME}/ | ||
+ | $ tar xvf ~/ | ||
+ | $ chmod -R -w gnu-mcu-eclipse/ | ||
+ | Check OpenOCD installation: | ||
+ | $ ${HOME}/ | ||
+ | Output should be something | ||
- | GNU MCU Eclipse 64-bits Open On-Chip Debugger 0.10.0+dev-00254-g2ec04e4e | + | GNU MCU Eclipse 64-bits Open On-Chip Debugger 0.10.0+dev-00404-g20463c28 |
Licensed under GNU GPL v2 | Licensed under GNU GPL v2 | ||
For bug reports, read | For bug reports, read | ||
- | http:// | + | http:// |
+ | Install UDEV rules for USB OpenOCD probes: | ||
+ | # cp ${HOME}/ | ||
+ | # udevadm control --reload-rules | ||
+ | # usermod -aG plugdev $USER | ||
+ | Install OpenOCD Debugging plugin, see [[https:// | ||
+ | Update OpenOCD path, see [[https:// | ||
+ | [[https:// | ||
+ | In Virtualbox make sure the STM-link/V2 adapter is connected through to virtual machine (check machine settings-> | ||
+ | In Eclipse hit green " | ||
=== GNU MCU Eclipse and CDT === | === GNU MCU Eclipse and CDT === | ||
* Install Eclipse and CDT | * Install Eclipse and CDT | ||
Line 80: | Line 110: | ||
$ tar xvf / | $ tar xvf / | ||
+ | Make the GNU Arm toolchain location known to Eclipse in Project-> | ||
=== Launch Eclipse to test installation === | === Launch Eclipse to test installation === | ||
Line 86: | Line 118: | ||
- | (grg seems not necessary, check installed plugins. first try if those compile run debug) | ||
- | === Install GNU MCU Eclipse plug-ins === | ||
- | * See https:// | ||
- | * In Eclipse: Help-> | ||
- | * GNU MCU C/C++ ARM Cross Compiler | ||
- | * GNU MCU C/C++ Documentation (Placeholder) | ||
- | * GNU MCU C/C++ OpenOCD Debugging | ||
- | * (GNU MCU C/C++ QEMU) ?? | ||
- | * GNU MCU C/C++ STM32Fx Project Templates | ||
- | (/grg) | ||
=== Build Test Project to check all is ok === | === Build Test Project to check all is ok === | ||
Line 102: | Line 123: | ||
=== Next step: import UHSDR into gnu arm eclipse === | === Next step: import UHSDR into gnu arm eclipse === | ||
- | [[en: | + | [[en: |
