Differences
en:uhsdr_dev:git [13.03.2018 12:45] – github additions 1 df9ts_user | en:uhsdr_dev:git [16.03.2018 13:09] (current) – [Further reading] df9ts_user | ||
Line 13: | Line 13: | ||
* If using Eclipse: create a work space pointing at the local directory where UHSDR has been unpacked. Check Eclipse settings after that (active build etc.) | * If using Eclipse: create a work space pointing at the local directory where UHSDR has been unpacked. Check Eclipse settings after that (active build etc.) | ||
- | ==== Option: Use " | + | ==== Option: Use " |
+ | A git cheat sheet can be found {{ : | ||
=== Fork UHSDR to your own remote github repo === | === Fork UHSDR to your own remote github repo === | ||
Line 26: | Line 28: | ||
* Check the remote repos assigned < | * Check the remote repos assigned < | ||
* Add DF8OE UHSD repo as upstream remote repo so that you can esaly synch it with your fork: < | * Add DF8OE UHSD repo as upstream remote repo so that you can esaly synch it with your fork: < | ||
- | * | + | * Check with "git remote -v" that upstream has been added. You now have two remote repos: " |
+ | === Rebase: Synchronising your fork with UHSDR DF8OE repo === | ||
+ | * You want to synchronise your forked UHSDR with the DF8OE main repo from time to time to include the latest changes of UHSDR into your fork. | ||
+ | * For that use < | ||
+ | * Your local fork is now synchronised with UHSDR DF8OE repo | ||
+ | * Next you need to push these changes to your remote github repo < | ||
+ | * Your github fork is now synchronised with DF8OE UHSDR main repo | ||
+ | === Creating branches for tests and experiments === | ||
+ | Before creating any new branch please pull the changes from upstream as explained above. Make sure your forked repo is up to date. | ||
+ | * Create the branch on your local machine and switch in this branch :< | ||
+ | * Change working branch : < | ||
+ | * Push the branch from local repo onto remote github : < | ||
+ | * When you want to commit something in your branch, be sure to be in your branch. Add -u parameter to set upstream. To check current branch use < | ||
+ | * Add a new remote for your branch : < | ||
+ | * Push changes from your commit into your branch : < | ||
+ | * Update your branch when the original branch from official repository has been updated : < | ||
+ | * Then you need to apply to merge changes, if your branch is derivated from develop you need to do : < | ||
+ | * Delete a branch on your local filesystem : < | ||
+ | * To force the deletion of local branch on your filesystem : < | ||
+ | * Delete the branch on github : < | ||
=== Use local UHSDR clone in Eclipse === | === Use local UHSDR clone in Eclipse === | ||
Line 57: | Line 78: | ||
==== Further reading ==== | ==== Further reading ==== | ||
https:// | https:// | ||
+ | http:// | ||
