Differences
Both sides previous revision Previous revision | Next revisionBoth sides next revision | ||
en:uhsdr_dev:git [13.03.2018 12:45] – github additions 1 df9ts_user | en:uhsdr_dev:git [13.03.2018 12:52] – github changes 2 df9ts_user | ||
Line 13: | Line 13: | ||
* If using Eclipse: create a work space pointing at the local directory where UHSDR has been unpacked. Check Eclipse settings after that (active build etc.) | * If using Eclipse: create a work space pointing at the local directory where UHSDR has been unpacked. Check Eclipse settings after that (active build etc.) | ||
- | ==== Option: Use " | + | ==== Option: Use " |
=== Fork UHSDR to your own remote github repo === | === Fork UHSDR to your own remote github repo === | ||
Line 26: | Line 26: | ||
* Check the remote repos assigned < | * Check the remote repos assigned < | ||
* Add DF8OE UHSD repo as upstream remote repo so that you can esaly synch it with your fork: < | * Add DF8OE UHSD repo as upstream remote repo so that you can esaly synch it with your fork: < | ||
- | * | + | * Check with "git remote -v" that upstream has been added. You now have two remote repos: " |
+ | === Rebase: Synchronising your fork with UHSDR DF8OE repo === | ||
+ | * You want to synchronise your forked UHSDR with the DF8OE main repo from time to time to include the latest changes of UHSDR into your fork. | ||
+ | * For that use < | ||
+ | * Your local fork is now synchronised with UHSDR DF8OE repo | ||
+ | * Next you need to push these changes to your remote github repo < | ||
+ | * Your github fork is now synchronised with DF8OE UHSDR main repo | ||
