en:uhsdr:uhsdrtroubleshooting
Differences
Link to this comparison view
Next revision
Previous revision
Next revisionBoth sides next revision
en:uhsdr:uhsdrtroubleshooting [12.02.2018 19:58] df9tsen:uhsdr:uhsdrtroubleshooting [12.02.2018 20:01] df9ts
Line 43: Line 43:
 === 3. Debug cable === === 3. Debug cable ===
 The debug cable shouldn't be longer than 10 cm. 3 to 4 connections are needed. The debug cable shouldn't be longer than 10 cm. 3 to 4 connections are needed.
-|< 40333333% >|+|< 60502525% >|
 |  ST-link adapter  |  OVI40 UI JP8  | |  ST-link adapter  |  OVI40 UI JP8  |
- Pin-13 TRACESWO  JP8 Pin 1  |  Debug Output +|Pin-13 TRACESWO  |JP8 Pin 1  |Debug Output
- Pin-15 NRST      |  JP8 Pin 2  |  Reset         | +|Pin-15 NRST      |JP8 Pin 2  |Reset         |
- Pin-07 SWDIO      JP8 Pin 3  |  Debug I/O     | +|Pin-07 SWDIO     |JP8 Pin 3  |Debug I/O     |
- Pin-09 SWCLK      JP8 Pin 4  |  Debug Clock   | +|Pin-09 SWCLK     |JP8 Pin 4  |Debug Clock   |
- Pin-01 MCU VDD    JP8 Pin 5  |  VDD from MCU  | +|Pin-01 MCU VDD   |JP8 Pin 5  |VDD from MCU  |
- Pin-20 Gnd        JP8 Pin 6  |  Ground        |+|Pin-20 Gnd       |JP8 Pin 6  |Ground        |
 {{ :uhsdr:en.dm00026748.pdf |Beschreibung ST-Link V2 und ST-Link ISO Adapter, Pin out}} {{ :uhsdr:en.dm00026748.pdf |Beschreibung ST-Link V2 und ST-Link ISO Adapter, Pin out}}
  • en/uhsdr/uhsdrtroubleshooting.txt
  • Last modified: 26.02.2018 18:58
  • by df9ts_user
