en:uhsdr:uhsdrbl
  • Option 1: Debug adapter approach. Preconditions:
    • STM “ST-Link V2” adapter, STM Link SW
  • Option 2: STM “Defuse” approach. Preconditions:
    • PC with STM Defuse Tool installed
    • USB to micro-USB cable (to connect PC with OVI40 mini-USB socket)
  • Option 3: USB-Stick approach. Preconditions:
    • USB stick with correct boot loader image
    • prior boot loader installation existing and working on OVI40 UI
  • *.bin file (pure binary file)
  • *.dfu file (containing binary and additional info such as target address on MCU)
Close P6 jumper in case:
  • There was never a UHSDR boot loader on the MCU (e.g. new assembled board)
  • Boot loader malfunctions, no upgrade with Defuse or USB-Stick possible
ToDo
Preconditions
  • Connect STM ST-Link V2 adapter to PC and to OVI40 UI.
  • ST-Link SW installed and running on PC, USB drivers installed, adapter recognized by PC
Procedure
Further Reading
ToDo
Preconditions
Procedure
  • Boot loader installation described here
Further reading
ToDo
Preconditions
  • OVI40 UI powered up with 5V (Pin 28 JP1) and 8V (Pin 29 JP1) and GND (Pin 30 JP1). The 8V powers the USB stick via voltage regulator
Procedure
  1. Supply +8V on JP1 pin 29 - to pwer USB stick
  2. Push and - important - hold switch “BAND -”
  3. Supply +5V on JP1 pin 28 - this starts the boot loader
  4. insert USB stick into large USB port of OVI40 UI
  5. Wait for FW upload to finish
  6. Release switch “Band -”
  7. Remove +5V, then apply again to reboot OVI40 UI.
  • en/uhsdr/uhsdrbl.1517851426.txt.gz
  • Last modified: 05.02.2018 17:23
  • by df9ts
