Differences
en:uhsdr:uhsdrbl [05.02.2018 17:22] – df9ts | en:uhsdr:uhsdrbl [12.02.2018 16:21] – [Check proper working of newly loaded boot loader] df9ts | ||
Line 1: | Line 1: | ||
- | {{tag> | + | |
- | ===== UHSDR Bootloader General Reading ===== | + | |
- | Forum: | + | |
- | * [[https:// | + | |
- | Github Wiki: | + | |
==== Bootloader Installation - General Comments ==== | ==== Bootloader Installation - General Comments ==== | ||
Three different options exist to do boot loader installation or upgrade: | Three different options exist to do boot loader installation or upgrade: | ||
* Option 1: Debug adapter approach. Preconditions: | * Option 1: Debug adapter approach. Preconditions: | ||
* Option 2: STM " | * Option 2: STM " | ||
- | * USB to micro-USB cable (to connect PC with OVI40 mini-USB socket) | + | * USB to micro-USB cable (to connect PC with OVI40 mini-USB socket) |
* Option 3: USB-Stick approach. Preconditions: | * Option 3: USB-Stick approach. Preconditions: | ||
- | * prior boot loader installation existing and working on OVI40 UI | + | * prior boot loader installation existing and working on OVI40 UI |
The latest boot loader SW can be found [[https:// | The latest boot loader SW can be found [[https:// | ||
* *.bin file (pure binary file) | * *.bin file (pure binary file) | ||
* *.dfu file (containing binary and additional info such as target address on MCU) | * *.dfu file (containing binary and additional info such as target address on MCU) | ||
Line 38: | Line 24: | ||
==== "P6 Jumper" | ==== "P6 Jumper" | ||
Close P6 jumper in case: | Close P6 jumper in case: | ||
* There was never a UHSDR boot loader on the MCU (e.g. new assembled board) | * There was never a UHSDR boot loader on the MCU (e.g. new assembled board) | ||
* Boot loader malfunctions, | * Boot loader malfunctions, | ||
Line 44: | Line 32: | ||
After closing jumper " | After closing jumper " | ||
- | After upgrade please **remember** to remove jumper P6 again!! | + | After upgrade please **remember** |
==== Option 1: ST-Link upgrade ==== | ==== Option 1: ST-Link upgrade ==== | ||
ToDo | ToDo | ||
=== Preconditions === | === Preconditions === | ||
- | * Connect STM ST-Link V2 adapter to PC and to OVI40 UI. | + | |
+ | * Connect STM ST-Link V2 adapter to PC and to OVI40 UI. | ||
* ST-Link SW installed and running on PC, USB drivers installed, adapter recognized by PC | * ST-Link SW installed and running on PC, USB drivers installed, adapter recognized by PC | ||
* OVI40 UI powered up with 5V (JP1) | * OVI40 UI powered up with 5V (JP1) | ||
Line 58: | Line 48: | ||
=== Further Reading === | === Further Reading === | ||
- | * [[http:// | + | |
* [[http:// | * [[http:// | ||
==== Option 2: DeFuse Tool upgrade ==== | ==== Option 2: DeFuse Tool upgrade ==== | ||
ToDo | ToDo | ||
* Install ST-Micro DeFuse Tool: [[http:// | * Install ST-Micro DeFuse Tool: [[http:// | ||
- | * Connect PC with OVI40 UI via USB - to - MiniUSB cable. Use MiniUSB plug on OVI40 UI | + | * Connect PC with OVI40 UI via USB - to - MiniUSB cable. Use MiniUSB plug on OVI40 UI |
* ST-Micro DFuse SW installed on PC and running, USB drivers installed, OVI40 UI recognized by PC | * ST-Micro DFuse SW installed on PC and running, USB drivers installed, OVI40 UI recognized by PC | ||
=== Procedure === | === Procedure === | ||
* Boot loader installation described {{: | * Boot loader installation described {{: | ||
=== Further reading === | === Further reading === | ||
- | * [[http:// | ||
+ | * [[http:// | ||
==== Option 3: USB-Stick upgrade upgrade ==== | ==== Option 3: USB-Stick upgrade upgrade ==== | ||
ToDo | ToDo | ||
* Format USB-Stick with FAT file partition. MAke sure - just in case - that USB-stick is otherwise empty | * Format USB-Stick with FAT file partition. MAke sure - just in case - that USB-stick is otherwise empty | ||
- | * Copy .bin file to stick. Make sure it is copied as file, not just a link / short-cut | + | * Copy .bin file to stick. Make sure it is copied as file, not just a link / short-cut |
* OVI40 UI powered up with 5V (Pin 28 JP1) and 8V (Pin 29 JP1) and GND (Pin 30 JP1). The 8V powers the USB stick via voltage regulator | * OVI40 UI powered up with 5V (Pin 28 JP1) and 8V (Pin 29 JP1) and GND (Pin 30 JP1). The 8V powers the USB stick via voltage regulator | ||
* Recent UHSDR boot loader installed and working | * Recent UHSDR boot loader installed and working | ||
- Supply +8V on JP1 pin 29 - to pwer USB stick | - Supply +8V on JP1 pin 29 - to pwer USB stick | ||
- Push and - important - hold switch "BAND -" | - Push and - important - hold switch "BAND -" | ||
Line 104: | Line 101: | ||
Remove Jumper P6 if previously closed, then boot UI. | Remove Jumper P6 if previously closed, then boot UI. | ||
- | Check boot loader | + | When booting the OVI40 UI a correctly installed |
+ | Please also check boot loader version number displayed in system menu corresponds to the version you intended to install. | ||
+ | ===== UHSDR Bootloader further reading ===== | ||
+ | Forum: | ||
+ | * [[https:// | ||
+ | Github Wiki: | ||
