Differences
en:projekte:ovi40-sdr:aufbautipps-ui-pcb [09.12.2017 14:44] – [In General] aus dem Deutschen übersetzt df9ts | en:projekte:ovi40-sdr:aufbautipps-ui-pcb [07.02.2018 06:06] (current) – df9ts_user | ||
Line 1: | Line 1: | ||
====== In General ====== | ====== In General ====== | ||
Line 35: | Line 36: | ||
So the I40 UI pcb should have the male connector strips on it. Its very useful to keep that rule which makes testing with the RF boards of different owners very easy. If you use a 24LC1025 type serial EEPROM fit R101. For all other EEPROM versions leave it out. | So the I40 UI pcb should have the male connector strips on it. Its very useful to keep that rule which makes testing with the RF boards of different owners very easy. If you use a 24LC1025 type serial EEPROM fit R101. For all other EEPROM versions leave it out. | ||
- | ===== Preparing the 3.2" LCD display | + | ===== 3.2" LCD is now obsolete - standard LCD of OVI40 becomes 3.5" |
- | The LCD display needs to be "treated" | + | |
- | The supporting pcb must be cut at the upper, bottom | + | 3.5" |
- | On the left side where the soldering holes were cut off, we have the potential danger that copper strips from the pcb can be possibly shorten by the metal frame of the panel. This can easily be avoided | + | |
- | To place the tape lift the panel approximately 0.5mm very carefully with a cutter knife and place the scotch tape under it. Fold it over the pcb edge. | + | |
- | If you do not have an LCD with double line connector strips at the right end, you need to place the connector strips with the long side of the pins from above (!) into the soldering holes. Solder them into place from the bottom side. | + | |
- | This way you do not need to remove the plastic carrier afterwards which may damage the panel connectors. | + | |
- | The short ends of the connector strip pins on the upper (plastic) side need to be cut off to finalize this step. | + | |
- | Special attention need to be payed here to the very sensitive flat ribbon cable to not damage it. A damage of the cable will most likely end up in totaling the LCD. | + | |
- | Attention should also be payed to not use too much solder to avoid little " | + | |
===== Detailed photos ===== | ===== Detailed photos ===== |
