Differences
en:projekte:ovi40-sdr:aufbautipps-ui-pcb [07.11.2017 11:45] – more information for Linux usage df8oe | en:projekte:ovi40-sdr:aufbautipps-ui-pcb [09.12.2017 14:44] – [In General] aus dem Deutschen übersetzt df9ts | ||
Line 1: | Line 1: | ||
====== In General ====== | ====== In General ====== | ||
- | 2do... | + | |
+ | SMD components are a reality in electronic gear since at least 15 years. Refusing to use SMD would mean refusing to accept reality. Soldering SMD components is quite different from soldering wired components. But soldering SMD is by far " | ||
Line 47: | Line 48: | ||
===== Detailed photos ===== | ===== Detailed photos ===== | ||
One picture says it all - The following photos show the fully populated UHSDR I40 UI pcb.: | One picture says it all - The following photos show the fully populated UHSDR I40 UI pcb.: | ||
- | {{: | + | Pictures coming soon! |
