Differences
en:projekte:ovi40-sdr:aufbautipps-ui-pcb [30.10.2017 16:26] – peter_77 | en:projekte:ovi40-sdr:aufbautipps-ui-pcb [09.12.2017 14:44] – [In General] aus dem Deutschen übersetzt df9ts | ||
Line 1: | Line 1: | ||
====== In General ====== | ====== In General ====== | ||
- | 2do... | + | |
+ | SMD components are a reality in electronic gear since at least 15 years. Refusing to use SMD would mean refusing to accept reality. Soldering SMD components is quite different from soldering wired components. But soldering SMD is by far " | ||
Line 47: | Line 48: | ||
===== Detailed photos ===== | ===== Detailed photos ===== | ||
One picture says it all - The following photos show the fully populated UHSDR I40 UI pcb.: | One picture says it all - The following photos show the fully populated UHSDR I40 UI pcb.: | ||
- | {{: | + | Pictures coming soon! |
Line 60: | Line 60: | ||
If not, supply voltage should be removed immediately and the pcb be checked for possible errors. | If not, supply voltage should be removed immediately and the pcb be checked for possible errors. | ||
If all is fine, connect the small USB connector to a PC. | If all is fine, connect the small USB connector to a PC. | ||
- | Under Windows OS you instantly hear the typical chime for new USB components and the taskbar shows an //STM in DFU mode// in the information bubble. Linux is a bit more "silent" | + | Under Windows OS you instantly hear the typical chime for new USB components and the taskbar shows an //STM in DFU mode// in the information bubble. |
- | Linux proofs | + | |
- | If yes, bootloader and firmware can be flashed with: | + | If all is fine, bootloader and firmware can be flashed with: |
Bootloader: //dfu-util -d -R -a 0 0483:df11 -D Pfad-zur/ | Bootloader: //dfu-util -d -R -a 0 0483:df11 -D Pfad-zur/ | ||
Line 72: | Line 71: | ||
Its the same way as its done with the originally mcHF UI board. | Its the same way as its done with the originally mcHF UI board. | ||
- | Actual firmware and bootloader versions can de downloaded here: [[https:// | + | Actual firmware and bootloader versions |
If this was all successfully completed, then remove the supply voltage and also remove jumper P6. Put the LCD panel into its connectors and reconnect the +5V voltage to pin 28. | If this was all successfully completed, then remove the supply voltage and also remove jumper P6. Put the LCD panel into its connectors and reconnect the +5V voltage to pin 28. | ||
You should now see the boot process with the UHSDR bootscreen and some error messages. These messages are expected, cause of the missing RF board. | You should now see the boot process with the UHSDR bootscreen and some error messages. These messages are expected, cause of the missing RF board. |
