Differences
en:projekte:ovi40-sdr:aufbautipps-ui-pcb [20.10.2017 13:38] – peter_77 | en:projekte:ovi40-sdr:aufbautipps-ui-pcb [09.12.2017 14:44] – [In General] aus dem Deutschen übersetzt df9ts | ||
Line 1: | Line 1: | ||
====== In General ====== | ====== In General ====== | ||
- | 2do... | + | |
+ | SMD components are a reality in electronic gear since at least 15 years. Refusing to use SMD would mean refusing to accept reality. Soldering SMD components is quite different from soldering wired components. But soldering SMD is by far " | ||
Line 24: | Line 25: | ||
Best practice is always to beginn with the most complicated component the STM32F7 / STM32H7. | Best practice is always to beginn with the most complicated component the STM32F7 / STM32H7. | ||
- | 99% of the work here is not the soldering, but as mentioned before, the correct positioning of the STM32 with his 144 pads. This needs to be done very precisely to avoid later problems. If the positioning is finished the following | + | 99% of the work here is not the soldering, but as mentioned before, the correct positioning of the STM32 with his 144 pads. This needs to be done very precisely to avoid later problems. If the positioning is finished, the following |
- | The two audio codecs are placed on the pcb the same way. When finished all three components should be classically cleaned from remaining flux with isopropyl alcohol. | + | The two audio codecs |
- | All remaining SMD components will then follow on the component side (STM32 side). There is only one single component on the front side. | + | All remaining SMD components will then follow on the component side (STM32 side). There is only one single |
- | Its recommended to finish one complete item from the list e.g. all 100nF/0603 then step to the next item e.g. all 0 Ohm resitors etc. | + | Its recommended to finish one complete item from the list e.g. all 100nF/ |
- | This is only a recommendation and everybody can follow his own plan here of course. | + | This is only a recommendation and of everybody can follow his own plan here of course. |
- | Soldering is finished | + | |
+ | Soldering is completed | ||
Recommendation for the connector strips is that connectors with electrical voltage and current should be kept female to avoid shortings. | Recommendation for the connector strips is that connectors with electrical voltage and current should be kept female to avoid shortings. | ||
- | So the I40 UI pcb should have the male connector strips on it. Its very useful to keep that rule which makes testing with the RF boards of different owners very easy. If you use 24LC1025 serial EEPROM fit R101. For all other EEPROM versions leave it out. | + | So the I40 UI pcb should have the male connector strips on it. Its very useful to keep that rule which makes testing with the RF boards of different owners very easy. If you use a 24LC1025 |
===== Preparing the 3.2" LCD display ===== | ===== Preparing the 3.2" LCD display ===== | ||
Line 46: | Line 48: | ||
===== Detailed photos ===== | ===== Detailed photos ===== | ||
- | One picture says it all - a couplke of photos which show the fully populated UI pcb.: | ||
- | {{: | + | One picture says it all - The following photos show the fully populated UHSDR I40 UI pcb.: |
- | {{: | + | Pictures coming soon! |
- | ====== Bringing the I40 UI pcb to work ====== | + | ====== Bringing the I40 UHSDR UI pcb to work ====== |
- | The UI pcb can, and of course should be, tested first before connecting it with any RF board. (I40 UI is fully compatible to the original mcHF RF board.) | + | The UI pcb can, and of course should be, tested first before connecting it with any RF board. (I40 UI is fully compatible to the original mcHF RF board versions.) |
The LCD panel should be left off here as well and jumper P6 needs to be bridged. | The LCD panel should be left off here as well and jumper P6 needs to be bridged. | ||
- | Connect pin 30 of the connector strip with ground and pin 28 with +5V. The actual current should be clearly under 80mA ! | + | Connect pin 30 of the upper male connector strip with ground and pin 28 with +5V. The actual current should be clearly under 80mA ! |
If not, supply voltage should be removed immediately and the pcb be checked for possible errors. | If not, supply voltage should be removed immediately and the pcb be checked for possible errors. | ||
- | If all is fine connect the small USB connector to a PC. | + | If all is fine, connect the small USB connector to a PC. |
- | Under Windows OS you hear the typical chime for new USB components and the taskbar shows an STM in DFU mode. Linux is a bit more silent here. | + | Under Windows OS you instantly |
- | Linux proofs | + | |
- | If yes, bootloader and firmware can be flashed with: | + | If all is fine, bootloader and firmware can be flashed with: |
Bootloader: //dfu-util -d -R -a 0 0483:df11 -D Pfad-zur/ | Bootloader: //dfu-util -d -R -a 0 0483:df11 -D Pfad-zur/ | ||
Line 68: | Line 68: | ||
Firmware: //dfu-util -d -R -a 0 0483:df11 -D Pfad-zur/ | Firmware: //dfu-util -d -R -a 0 0483:df11 -D Pfad-zur/ | ||
- | Windows users do the same here with the well known "DfuSE Demo" tool from STM. Its the same way as its done with the originally mcHF UI board. | + | Windows users do the bootcode and first firmware flashing |
+ | Its the same way as its done with the originally mcHF UI board. | ||
- | Actual firmware and bootloader versions can de downloaded here: [[https:// | + | Actual firmware and bootloader versions |
- | If this was all successful, then remove the supply voltage and also remove jumper P6. Put the LCD panel into its connectors and reconnect the +5V voltage to pin 28. | + | If this was all successfully completed, then remove the supply voltage and also remove jumper P6. Put the LCD panel into its connectors and reconnect the +5V voltage to pin 28. |
You should now see the boot process with the UHSDR bootscreen and some error messages. These messages are expected, cause of the missing RF board. | You should now see the boot process with the UHSDR bootscreen and some error messages. These messages are expected, cause of the missing RF board. |
