Next revision | Previous revision |
en:ovi40what:specs [20.01.2018 20:15] – created df9ts_user | en:ovi40what:specs [06.06.2018 18:54] (current) – df9ts |
{{tag>missinginfo}} | {{tag>english}}{{tag>missinginfo}} |
===== OVI40 Short Specification ===== | ===== OVI40 Short Specification ===== |
==== OVI40-SDR Components ==== | ==== OVI40-SDR Components ==== |
The OVI40-SDR consists of the following components: | The OVI40-SDR consists of the following components: |
* UI Board | |
| * UI Board |
* Display und Touchscreen Module | * Display und Touchscreen Module |
* RF Board | * RF Board |
|< 95% 15% 80% >| | |< 95% 15% 80% >| |
|PCB Dimensions: |186mm x 66mm | | |
|Processor: |STM32F76x (216 MHz Clock), \\ optional STM32H743ZIT6 (400 MHz Clock, pin compatible with STM32F76x) | | |PCB Dimensions: |186mm x 66mm | |
|Audio Codec: |2 x WM8731 @ 96KHz (UHSDR currently using 48 kHz only), separate IQ and Audio \\ (TX and RX possible simultaneously, RF board needs to support this) | | |Processor: |STM32F76x (216 MHz Clock), \\ optional STM32H743ZIT6 (400 MHz Clock, pin compatible with STM32F76x) | |
|Display: |3.5" 480×320 as default, 3.2" and 2.8" supported | | |Audio Codec: |2 x WM8731 @ 96KHz (UHSDR currently using 48 kHz only), separate IQ and Audio \\ (TX and RX possible simultaneously, RF board needs to support this) | |
|LCD Interface: |parallel and SPI supported, parallel used as default | | |Display: |3.5" 480×320 as default, 3.2" and 2.8" supported | |
|Internal memory: |SPI-Flash (Option), SPI-RAM (Option) | | |LCD Interface: |parallel and SPI supported, parallel used as default| |
|External memory: |microSD card | | |Internal memory: |SPI-Flash (Option), SPI-RAM (Option) | |
|Realtime clock: |integrated Realtime Clock (RTC) part of STM32 MCU, CR2032 Backup Battery | | |External memory: |microSD card | |
|LEDs: |3 | | |Realtime clock: |integrated Realtime Clock (RTC) part of STM32 MCU, CR2032 Backup Battery | |
|External connections: |Mini-USB Type B, USB-Host (USB-A), \\ 3.5mm connector for microphone and PTT, 3.5mm connector for analog input, \\ 3.5mm connector for analog output (line-out is independant from loudspeaker), 3.5mm connector for headset | | |LEDs: |3 | |
|Internal connections: |30pin connector (mcHF RF Board compatible), 6pin GPIO, 25pin connector (GPIOs, SPI, I2C), ST-Link V2 compatible Debug connector, Debug output, 2 x 4 Pin internal USB connections | | |External connections:|Mini-USB Type B, USB-Host (USB-A), \\ 3.5mm connector for microphone and PTT, 3.5mm connector for analog input, \\ 3.5mm connector for analog output (line-out is independant from loudspeaker), 3.5mm connector for headset | |
|Keys: |18 separate keys | | |Internal connections:|30pin connector (mcHF RF Board compatible), 6pin GPIO, 25pin connector (GPIOs, SPI, I2C), ST-Link V2 compatible Debug connector, Debug output, 2 x 4 Pin internal USB connections | |
|Rotary encoders: |4 rotary encoders with integrated key function | | |Keys: |18 separate keys | |
|Audio output: |Stereo, 2 x 3W at 2 x 4 Ohm with less than 1% THD+N | | |Rotary encoders: |4 rotary encoders with integrated key function | |
The 30pin header J1 is downward compatible with the [[http://www.m0nka.co.uk/|mcHF]] RF boards up to and including RF board V0.6. OVI40 UI and mcHF RF board can be used together. An improved OVI40 RF Board is in development. | The 30pin header J1 is downward compatible with the [[http://www.m0nka.co.uk/|mcHF]] RF boards up to and including RF board V0.6. OVI40 UI and mcHF RF board can be used together. An improved OVI40 RF Board is in development. |
==== Display Board ==== | ==== Display Board ==== |
<bootnote>ToDo Photo</bootnote> | <bootnote>ToDo Photo</bootnote> |
|Displaygröße: |3.5 inch | | |
|Display Typ |TN | | |
|Auflösung: |480 x 320 | | |
|Kontroller: |ILI9846 (und kompatible) | | |
|Bedienung: |Touchscreen | | |
|Schnittstelle: |SPI und Parallel | | |
Ebenfalls benutzt werden könen 2.8 inch oder 3.2 inch 320 x 240 Touchscreen Displays mit IL9325 (oder kompatiblem) Kontroller. | |Display size: |3.5 inch | |
| |Display Type |TN | |
| |Resolution: |480 x 320 | |
| |Controller: |ILI9846 (and compatible) | |
| |Human Interface: |Touchscreen | |
| |Interface: |SPI and Parallel | |
==== RF Board ==== | 2.8 inch oder 3.2 inch 320 x 240 Touchscreen Displays mit IL9325 (or compatible) controller can also be used. |
<bootnote>ToDo Photo und Datentabelle</bootnote> | ==== RF Board ==== |
==== Gehäuse ==== | <bootnote>ToDo Photo and Data table</bootnote> |
<bootnote>ToDo Gehäusetext und Daten</bootnote> | ==== Housing ==== |
| <bootnote>ToDo GHousing text and data</bootnote> OVI40 will not fit the current mcHF casings. In contrast to the mcHF, the OVI40 RF boards will have additional PCB boards plugged into them. It is assumed that these adapter boards may be up to 5 cm long. There will be OVI40 specific casings developped and provided who do not want to build their own housing. These housings will be developped after the OVI40 has been finished. |
