en:ovi40test:uiboardtest
The MCU seems to have two (!) pin 1 marks. Watch text orientation on MCU to find “real” pin 1.
In case of missing audio out: just in case, please check the SW_12V connection. This is power supply connector for Audio power amplifier stage unlike the mcHF.
  • RTC clock crystal and TXCO are prerequisite for flash programming to work
  • Check correct orientation of TXCO (see photo on this page)
  • Check 3.3V at C95. If not present then L3 may be defective
With the kit resistors the LEDs are quite bright. DF9EH has reduced the values as follows:
  • R36 22k6 (D1 green)
  • R37 6k8 (D2 red)
  • R116 6k8 (D3 blue)
In case you see this UHSDR error message please check +3V supply for codecs (WM8731) is ok. This +3V supply is generated on RF board.
First check that MCU is soldered in in correct orientation (see above “Pin 1”).
In order to boot the MCU needs:
  • CPU clock (→ check TXCO clock)
  • correct reset voltage over time at boot up (→ check voltage over time, check voltage levels at reset pin of MCU)
Only if thos pre-conditions are met will the MCU work with DfuSe or ST-Link/V2 and closed jumper “P6”.
Only after bootloader starts correctly will pin voltages for switches, LEDs and LCD be initialized to some extend., e.g. “Band+” and “Band-” switch.
Also check:
  • Does PC recognize the OVI40 UI board connected via USB cable, as USB device in device manager?
  • PC USB port working? USB cable ok?
  • Check all MCU pins are correctly soldered and no shortcuts exist: Use a thin knife / scalpell / tweezer, go inbetween MCU pins and try to push the pins gently sideways one by one, check if all are soldered to PCB. If not the pin moves slightly.
Please check +8V supply from Rf-Board, JP1.
  • en/ovi40test/uiboardtest.txt
  • Last modified: 08.02.2018 20:50
  • by df9ts
