Differences
en:ovi40build:uiboardbuild [03.02.2018 10:42] – [Modifications] Disco F746 added df9ts_user | en:ovi40build:uiboardbuild [02.03.2018 18:13] (current) – df9ts_user | ||
Line 1: | Line 1: | ||
- | {{tag> | ||
- | ===== Building the UI V1.8 Board ===== | ||
- | ==== OVI40 UI V1.7 Documents ==== | ||
- | **UI V1.7 documents are provided for information only**. Please primarily use the V1.8 documents for building the UI V1.8 board. | ||
- | Please note that the component placement docs are searchable pdf documents. During soldering they can be used to quickly find a component' | ||
- | ==== OVI40 UI V1.8 Documents ==== | ||
- | ==== OVI40 UI V1.8 Kit Contents ==== | ||
- | The kit contains UI V1.8 PCB, components in bags and packing list. The display is delivered as assembled and tested unit. | ||
- | |< 60% 33% 33% 33% >| | ||
- | ==== Assembly and Soldering ==== | ||
- | The graphics below - UI V1.7 with 3.2" Display - give an impression on how the finished V1.8 UI board will look like: | ||
- | |< 95% 50% 50% >| | ||
- | === Please read Errata carefully === | ||
- | Make sure to read the [[en: | ||
- | === IC Device Markings === | ||
- | The smaller ICs can be identified by device mark. The following device marks are used: | ||
- | |< 45% 25% 25% 25% 25% >| | ||
- | |Typ |Device Mark |Schematic | ||
- | |LP5907_Q1 | ||
- | |BAV70 | ||
- | |BC857B | ||
- | |BAS85 | ||
- | === MCU STM32 "Pin 1" marking === | ||
- | Please understand the correct orientation of STM32 MCU Pin 1. There are two markings on the IC. Please not the text printed on MCU to find the correct Pin 1: When reading the text Pin 1 is on bottom left corner. | ||
- | === STM32F76X_ZIT vs. STM32H743ZIT6 === | ||
- | The kit is shipped with STM32F76X_ZIT (" | ||
- | Comparison of MCUs: | ||
- | |< 90% 25% 25% 25% 25% >| | ||
- | |Flash[kB] | ||
- | |Clock[MHz] | ||
- | |FPU |single | ||
- | |Pins |100 |144 |144 | | ||
- | |DMIPS | ||
- | === EEPROM IC7 orientation === | ||
- | This is where the dot is printed. Also the edge of the case is slanted near the 1-4 pins. See [[http:// | ||
- | **Do not solder in R101** for the EEPROM delivered with the kit (AT24CM02). | ||
- | === Prevent short cut with back up battery holder === | ||
- | One of the connection pins of the battery holder might touch ground connection of a rotary encoder. Make sure to cut this pin flush with PCB surface **before soldering** | ||
- | === Polarised capacitors === | ||
- | Please observe mounting orientation of tantal and electrolytic capacitors. Markings on the capacitors are explained [[http:// | ||
- | === Mounting locations of switches S7 and S8 === | ||
- | Two different mounting locations are provided on the UI PCB for S7 and S8: | ||
- | * "mcHF style": | ||
- | * "OVI40 style": | ||
- | "In line" is the preferred mounting location for S7 and S8. | ||
- | === IC9 und IC11: leave empty for now === | ||
- | IC9 (SPI FRAM) and IC11 (SPI FLASH) are for future use. Please leave empty for now. They are neither required nor supported by UHSDR at this time. | ||
==== Modifications ==== | ==== Modifications ==== | ||
=== Temporary Modification: | === Temporary Modification: | ||
- | Symptom: In stand-by the current drawn from back-up battery is excessively high. Work-around: | + | Symptom: In stand-by the current drawn from back-up battery is excessively high. Work-around: |
=== Change brightness of LEDs === | === Change brightness of LEDs === | ||
Line 120: | Line 12: | ||
