en:ovi40build:uiboardbuild
Please note that the component placement docs are searchable pdf documents. During soldering they can be used to quickly find a component's location by entering the component reference (e.g. “R20”) in pdf search. No need to be concerned to use the V1.7 component placement doc for assembling a V1.8 UI board - V1.7 and V1.7 are quite similar in this respect.
Components in bags (Foto: DL8EBD)
UI V1.8 PCB (Foto: DL8EBD)
Display board (Foto: DL8EBD)
UI Board V1.7 mit 3.2” Display)
UI Board V1.7
Please read Errata carefully
  === IC Device Markings ===
LP5907_Q1 LLVB IC3 LDO 3.3 V
BAV70 A4 D5, D6 Diode
BC857B 3F T3 Transistor
MCU STM32 "Pin 1" marking
  === STM32F76X_ZIT vs. STM32H743ZIT6 ===
Comparison of MCUs:
mcHF: OVI40: OVI40 - future:
Flash[kB] 500 2048 2048
RAM [kB] 192 512 1024
Clock[MHz] 168 216 400
FPU single double double
Pins 100 144 144
DMIPS 210 462 856
EEPROM IC7 orientation
Do not solder in R101 for the EEPROM delivered with the kit (AT24CM02).
Polarised capacitors
  • “mcHF style”: S7 and S8 not line with switches under LCD - they are mounted slightly higher
  • “OVI40 style”: S7 and S8 are mounted in line with the function keys under the LCD
Symptom: In stand-by the current drawn from back-up battery is excessively high. Work-around: Put resistor in parallel to C94. Start with a value of 56k - this seems to work in most cases. If board does not start increase value slightly.
Change brightness of LEDs
  • R36 auf 22,6k (D1 grün)
  • R37 auf 6,8k (D2 rot)
  • R116 auf 6,8k (D3 blau)
  • en/ovi40build/uiboardbuild.1517168421.txt.gz
  • Last modified: 28.01.2018 19:40
  • by df9ts_user
