en:ovi40build:uiboardbuild
Please note that the component placement docs are searchable pdf documents. During soldering they can be used to quickly find a component's location by entering the component reference (e.g. “R20”) in pdf search.
Components in bags (Foto: DL8EBD)
UI V1.8 PCB (Foto: DL8EBD)
Display board (Foto: DL8EBD)
UI Board V1.7 mit 3.2” Display)
UI Board V1.7
Please read Errata carefully
IC Device Markings
LP5907_Q1 LLVB IC3 LDO 3.3 V
BAV70 A4 D5, D6 Diode
BC857B 3F T3 Transistor
MCU STM32 "Pin 1" marking
Comparison of MCUs:
mcHF: OVI40: OVI40 - future:
Flash[kB] 500 2048 2048
RAM [kB] 192 512 1024
Clock[MHz] 168 216 400
FPU single double double
Pins 100 144 144
DMIPS 210 462 856
EEPROM IC7 orientation
Polarised capacitors
  • “mcHF style”: S7 and S8 not line with switches under LCD - they are mounted slightly higher
  • “OVI40 style”: S7 and S8 are mounted in line with the function keys under the LCD
Symptom: In stand-by the current drawn from back-up battery is excessively high. Work-around: Put resistor in parallel to C94. Start with a value of 56k - this seems to work in most cases. If board does not start increase value slightly.
Change brightness of LEDs
  • R36 auf 22,6k (D1 grün)
  • R37 auf 6,8k (D2 rot)
  • R116 auf 6,8k (D3 blau)
  • en/ovi40build/uiboardbuild.1516868998.txt.gz
  • Last modified: 25.01.2018 08:29
  • by df9ts
