en:ovi40build:ovi40_batch1uiboarderrata
Differences
Link to this comparison view
Next revision
Previous revision
en:ovi40_batch1uiboarderrata [14.01.2018 08:26] df9tsen:ovi40build:ovi40_batch1uiboarderrata [07.02.2018 05:59] (current) df9ts_user
Line 1: Line 1:
-====== Errata for OVI40 Batch 1 kit delivery ======+{{tag>english}}{{tag>publish}}
 +====== Errata for OVI40 UI V1.8 Batch 1 kit delivery ======
 Source: Source:
Line 5: Line 6:
 ===== In Kit Bag 1 ===== ===== In Kit Bag 1 =====
-  * 3.5 mm Stereo Connectors J1, J2, J3 plastic noses won’t fit the PCB holes</font>+  * 3.5 mm Stereo Connectors J1, J2, J3 plastic noses won’t fit the PCB holes
     * Cut the plastic noses or use fitting socket Lumberg 1503-7 (Reichelt LUM 1503-07, Conrad 738788)     * Cut the plastic noses or use fitting socket Lumberg 1503-7 (Reichelt LUM 1503-07, Conrad 738788)
   * The 470 nF capacitors have size 0805, however size 0603 is required according to PCB Layout and BoM. Can still be soldered in   * The 470 nF capacitors have size 0805, however size 0603 is required according to PCB Layout and BoM. Can still be soldered in
Line 19: Line 20:
   * The capacitors (8,2pF-10pF) are 0402 but should be 0603. Can still be soldered in.   * The capacitors (8,2pF-10pF) are 0402 but should be 0603. Can still be soldered in.
-==== Other ====+===== Other =====
   * R2, R6, R7, R10-12,R15, R25, R40 have 0603 footprint in BOM but on PCB we have 0805. Can still be soldered in   * R2, R6, R7, R10-12,R15, R25, R40 have 0603 footprint in BOM but on PCB we have 0805. Can still be soldered in
   * C100 is marked “COO” (letter "O" instead of digit "0") instead in schematics (so can’t be found with Acrobat Reader in schematic   * C100 is marked “COO” (letter "O" instead of digit "0") instead in schematics (so can’t be found with Acrobat Reader in schematic
  • en/ovi40build/ovi40_batch1uiboarderrata.1515918378.txt.gz
  • Last modified: 14.01.2018 08:26
  • by df9ts
