Differences
en:ovi40build:displaybuild [18.02.2018 13:58] – df9ts | en:ovi40build:displaybuild [15.05.2018 13:18] (current) – [Display Assembly] df8oe | ||
Line 16: | Line 16: | ||
* 3.2" display 320 x 240 witch controller IL9325 (or IL9325 compatible controller): | * 3.2" display 320 x 240 witch controller IL9325 (or IL9325 compatible controller): | ||
* 2.8" display 320 x 240 with controller IL9325 (or compatible controller): | * 2.8" display 320 x 240 with controller IL9325 (or compatible controller): | ||
Line 24: | Line 25: | ||
- | Start the calibration by touching the touch screen with a finger **before** | + | Start the calibration by touching the touch screen with a finger **before** |
+ | Sometimes calibration fails and there is need to repeat it. That's why there is a test screen with drawing dots (you can use also the blue test screen to check if it works). You have to play with it to be familiar. If the accuracy is not perfect (it should be less than 1mm) you have to change the calibration method or have issue with the panel itself. One preferred method for calibration is to use plastic stylus or soft pencil (gentle), but you can do it with nail with good results. | ||
==== Mechanical fixing of the display board onto the UI board ==== | ==== Mechanical fixing of the display board onto the UI board ==== | ||
Line 66: | Line 69: | ||
This pdf contains th modified assembly notes: {{: | This pdf contains th modified assembly notes: {{: | ||
- | * C103 not needed anymore | + | * C103, C112, IC103 and R106 are not needed anymore |
- | * R106 = 1K | ||
+ | * R105 = 3.3R | ||
* all 10u now replaced by 1u | * all 10u now replaced by 1u | ||
+ | Put a small wire between pin3 and pin4 of IC103. Shorten R107 forever. | ||
+ | LCD can only work in parallel mode - there //will never be a SPI mode.// | ||
DF8OE suggest to replace the two parallel tantal capacitors next to the 3.3V voltage regulator by 100nF & 1uF. He also suggest to put 100nF & 1uF in the free location shown in Andy's photo. | DF8OE suggest to replace the two parallel tantal capacitors next to the 3.3V voltage regulator by 100nF & 1uF. He also suggest to put 100nF & 1uF in the free location shown in Andy's photo. | ||
Line 86: | Line 93: | ||
+ | ==== On shortening the male header J103 on OVI40 UI for LCD display ==== | ||
+ | Cutting the male header pins pf J103 (on component side) is required to reduce height of the LCD Display module above OVI40 UI PCB. Cutting / shortening the pins on component side might not be the best idea as it damages the female connector each time it's inserted, due to the fact that cutting the J103 pins produces sharp edges that scratch the femaile LCD display header. | ||
+ | An alternative is to solder the pins at the right depth and then cut the pins flush to the pcb on the solder side. | ||
