Differences
en:ovi40build:displaybuild [18.02.2018 13:58] – df9ts | en:ovi40build:displaybuild [25.04.2018 07:26] – df9ts | ||
Line 16: | Line 16: | ||
* 3.2" display 320 x 240 witch controller IL9325 (or IL9325 compatible controller): | * 3.2" display 320 x 240 witch controller IL9325 (or IL9325 compatible controller): | ||
* 2.8" display 320 x 240 with controller IL9325 (or compatible controller): | * 2.8" display 320 x 240 with controller IL9325 (or compatible controller): | ||
Line 86: | Line 87: | ||
+ | ==== On shortening the male header J103 on OVI40 UI for LCD display ==== | ||
+ | Cutting the male header pins pf J103 (on component side) is required to reduce height of the LCD Display module above OVI40 UI PCB. Cutting / shortening the pins on component side might not be the best idea as it damages the female connector each time it's inserted, due to the fact that cutting the J103 pins produces sharp edges that scratch the femaile LCD display header. | ||
+ | An alternative is to solder the pins at the right depth and then cut the pins flush to the pcb on the solder side. | ||
