en:ovi40build:displaybuild
Differences
Link to this comparison view
Next revision
Previous revision
Last revisionBoth sides next revision
en:ovi40build:displaybuild [28.01.2018 07:28] – created df9ts_useren:ovi40build:displaybuild [25.04.2018 07:28] – [Display Calibration - mandatory at first bring-up] included post of Slawek df9ts
Line 1: Line 1:
 {{tag>english}}{{tag>publish}} {{tag>english}}{{tag>publish}}
 ===== Display Board Building ===== ===== Display Board Building =====
 ==== 3.5" is the OVI40-SDR standard default display ==== ==== 3.5" is the OVI40-SDR standard default display ====
 The 3.5 inch LCD panel has exactly the same outer dimensions as the PCB porting plate of the previous 3.2 inch display. The key switches S7 and S8 on the UI board need to be mounted in the "lower" positions (i.e. in line with the function keys below LCD), in order not to be in the way. The 3.5 inch LCD panel has exactly the same outer dimensions as the PCB porting plate of the previous 3.2 inch display. The key switches S7 and S8 on the UI board need to be mounted in the "lower" positions (i.e. in line with the function keys below LCD), in order not to be in the way.
 ==== Display Board ==== ==== Display Board ====
 The display board plugs into UI board vonnector directly. The display board contains LCD display and touch panel functionality. For mechanical mounting oDie Displayplatine beinhaltet Display und Touchpanel. For mechanical mounting considerations please see below. The display board plugs into UI board vonnector directly. The display board contains LCD display and touch panel functionality. For mechanical mounting oDie Displayplatine beinhaltet Display und Touchpanel. For mechanical mounting considerations please see below.
 The following LCDs can be used with UI board V1.8 and UHSDR: The following LCDs can be used with UI board V1.8 and UHSDR:
-  * 3.5" display 480x320 with controller ILI9846 (ot ILI9846 compatible controller): OVI40 default display+
 +  * 3.5" display 480×320 with controller ILI9846 (ot ILI9846 compatible controller): OVI40 default display
   * 3.2" display 320 x 240 witch controller IL9325 (or IL9325 compatible controller): this was the display used during UI V1.8 beta testing   * 3.2" display 320 x 240 witch controller IL9325 (or IL9325 compatible controller): this was the display used during UI V1.8 beta testing
   * 2.8" display 320 x 240 with controller IL9325 (or compatible controller): this is the mcHF defult display   * 2.8" display 320 x 240 with controller IL9325 (or compatible controller): this is the mcHF defult display
-|< 95% 50% 50% >|
-|  [{{:projekte:ovi40-sdr:i40_23.jpg?400|OVI40 3.5" display (photo DL8EBD)}}]  |  [{{:projekte:ovi40-sdr:i40_24.jpg?400|OVI40 3.5" display, component side (photo:DL8EBD)}}]  |
-==== Display Calibration - mandatory at first bring-up==== +|< 95% 50% 50% >|
-<bootnote important>It is mandatory to do a display calibration at first bring-up / switch on of the touch screen display. Only after calibration will the touch screen work with UHSDR.</bootnote> +
-The calibration is required initially. No later calibration needed during operation.+|  [{{:projekte:ovi40-sdr:i40_23.jpg?400|OVI40 3.5" display (photo DL8EBD)}}]  |  [{{:projekte:ovi40-sdr:i40_24.jpg?400|OVI40 3.5" display, component side (photo:DL8EBD)}}]
 +==== Display Calibration - mandatory at first bring-up ====
 +<bootnote important>It is mandatory to do a display calibration at first bring-up / switch on of the touch screen display. Only after calibration will the touch screen work with UHSDR.</bootnote>. The calibration is required initially. No later calibration needed during operation
 +Start the calibration by touching the touch screen with a finger **before**  switching on the UI board V1.8. Keep touching the touch screen until the service menu sis displayed. Now release the finger from the touch screen and follow instructions on the screen carefully. After calibration is finished please leave the test screen by pressing the POWER button and then, when firmware start to work, please long press MENU (F1) button to save the calibration settings (the MENU should be marked with * and different colour, which means you have not saved settings).
-Start the calibration by touching the touch screen with a finger **before** switching on the UI board V1.8Keep touching the touch screen until the service menu sis displayed. Now release the finger from the touch screen and follow instructions on the screen carefully +Sometimes calibration fails and there is need to repeat it. That's why there is a test screen with drawing dots (you can use also the blue test screen to check if it works)You have to play with it to be familiarIf the accuracy is not perfect (it should be less than 1mm) you have to change the calibration method or have issue with the panel itselfOne preferred method for calibration is to use plastic stylus or soft pencil (gentle), but you can do it with nail with good results.
-After calibration is finished please save the calibration by long-pressing the "menu" button switch on the UI board+
 ==== Mechanical fixing of the display board onto the UI board ==== ==== Mechanical fixing of the display board onto the UI board ====
-The display board will be mechanically held in position by the casing. As long as the casing is not available yet, a temporary solution is required.
-Simple approach: a piece of non-conductive material (e.g. plastic) of suitable height can be fixed between UI board and LCD PCB with double-sided self-adhesive tape. This will keep the display board stabilized and away from the UI board+The display board will be mechanically held in position by the casing. As long as the casing is not available yet, a temporary solution is required.
-Just make sure that it is still possible to easy unplugging of the display board is still possible, when needed. +Simple approach: a piece of non-conductive material (e.g. plastic) of suitable height can be fixed between UI board and LCD PCB with double-sided self-adhesive tape. This will keep the display board stabilized and away from the UI board.
 +Just make sure that it is still possible to easy unplugging of the display board is still possible, when needed.
 Alternatively plastic spacer bolts may be used: Alternatively plastic spacer bolts may be used:
-**Option 1** plastic spacer Plastik-Abstandshalter with inner thread and outer thread, e.g. [[ +**Option 1**  plastic spacer Plastik-Abstandshalter with inner thread and outer thread, e.g. [[https://www.tme.eu/pl/details/tp-11/tuleje-dystansowe-plastikowe/fixfasten/|https://www.tme.eu/pl/details/tp-11/tuleje-dystansowe-plastikowe/fixfasten/]]. Please refer to photo below: the outher thread is cut flush with the display PCB board, then glued. The spacer bolt is fixed onto the UI board with adhesive tape.
-https://www.tme.eu/pl/details/tp-11/tuleje-dystansowe-plastikowe/fixfasten/]]. Please refer to photo below: the outher thread is cut flush with the display PCB board, then glued. The spacer bolt is fixed onto the UI board with adhesive tape.+
-**Option 2** plastic spacer bolt with two inner threads, e.g. [[https://www.tme.eu/pl/details/hp-10/tuleje-dystansowe-plastikowe/fixfasten/]]. This spacer bolt is fixed with display PCB by screw and fixed to UI PCB by adhesive tape.+**Option 2**  plastic spacer bolt with two inner threads, e.g. [[https://www.tme.eu/pl/details/hp-10/tuleje-dystansowe-plastikowe/fixfasten/|https://www.tme.eu/pl/details/hp-10/tuleje-dystansowe-plastikowe/fixfasten/]]. This spacer bolt is fixed with display PCB by screw and fixed to UI PCB by adhesive tape.
 |< 95% 50% 50% >| |< 95% 50% 50% >|
-|  [{{:ovi40build:plastic_glued.jpg?400|Option 1 - Spacer glued (photo SP9BSL)}}]  |  [{{:ovi40build:plastic_with_pem.jpg?400|Option 2  +
- - TEM screw (Photo SP9BSL)}}]  |+|  [{{:ovi40build:plastic_glued.jpg?400|Option 1 - Spacer glued (photo SP9BSL)}}]  |  [{{:ovi40build:plastic_with_pem.jpg?400|Option 2 - TEM screw (Photo SP9BSL)}}]  |
 ==== Display Brightness ==== ==== Display Brightness ====
-The LCD display brightness can be adjusted by changing R105 (15 Ohm default) to a different vlue. R105 is next to the SOIC8-IC +
 +The LCD display brightness can be adjusted by changing R105 (15 Ohm default) to a different vlue. R105 is next to the SOIC8-IC
 According to LCD data sheet the maximum DC current allowed is 60 mA continous, or 75 mA for less than a minute. When changing R105 please make sure not to exceed 60 mA. According to LCD data sheet the maximum DC current allowed is 60 mA continous, or 75 mA for less than a minute. When changing R105 please make sure not to exceed 60 mA.
Line 48: Line 56:
 ==== Cutting SDO line ==== ==== Cutting SDO line ====
 <bootnote> It is necessary to cut the SDO line for all LCD display boards delivere befor January 5, 2018. Displays delivered later have this modification already. </bootnote> <bootnote> It is necessary to cut the SDO line for all LCD display boards delivere befor January 5, 2018. Displays delivered later have this modification already. </bootnote>
Line 55: Line 64:
 ==== Display Assembly ==== ==== Display Assembly ====
 <bootnote> The display board is delivered as an assembled and tested unit. Explanations below refer to self-assembly, not required, and are added for completeness and reference only </bootnote> <bootnote> The display board is delivered as an assembled and tested unit. Explanations below refer to self-assembly, not required, and are added for completeness and reference only </bootnote>
-This pdf contains th modified assembly notes:  +This pdf contains th modified assembly notes: {{:projekte:ovi40-sdr:lcd_35_40pin_df8oe_sp9bsl.pdf|lcd_35_40pin_df8oe_sp9bsl.pdf}}
-{{:projekte:ovi40-sdr:lcd_35_40pin_df8oe_sp9bsl.pdf|lcd_35_40pin_df8oe_sp9bsl.pdf}}+
   * C103 not needed anymore   * C103 not needed anymore
Line 67: Line 76:
   * XPT2046 = ADS7843E   * XPT2046 = ADS7843E
-DF8OE suggest to replace the two parallel tantal capacitors next to the 3.3V voltage regulator by 100nF & 1uF. He also suggest to put 100nF & 1uF in the free location shown in Andy's photo. +DF8OE suggest to replace the two parallel tantal capacitors next to the 3.3V voltage regulator by 100nF & 1uF. He also suggest to put 100nF & 1uF in the free location shown in Andy's photo.
 The two pads of R107 location need to be short cut, otherwise the LCD won't work. The two pads of R107 location need to be short cut, otherwise the LCD won't work.
-Only LCD **parallel mode** is supported at this time. +Only LCD **parallel mode**  is supported at this time.
 === Possitioning the LCD on the PCB === === Possitioning the LCD on the PCB ===
 The lower left corner of the LCD should be flush with the PCB. The lower left corner of the LCD should be flush with the PCB.
-Dazu die LCD links unten ansetzen und sie bei bereits eingestecktem Flachkabel  vorsichtig in Richtung PCB umklappen. Irgendwann geht es schwerer - weil das Flachkabel jetzt zwischen LCD und PCB Wellen schlägt. Nun auf der Seite der PCB mit dem FPC mit einem Schraubendreher zwischen Flachkabel und PCB gehen und vorsichtig eine kleine Schlaufe rausziehen. Das LCD klappt nun wie von selbst gegen die PCB und kann  vorsichtig (!!) am linken, oberen und unteren Rand angedrückt werden.+Dazu die LCD links unten ansetzen und sie bei bereits eingestecktem Flachkabel vorsichtig in Richtung PCB umklappen. Irgendwann geht es schwerer - weil das Flachkabel jetzt zwischen LCD und PCB Wellen schlägt. Nun auf der Seite der PCB mit dem FPC mit einem Schraubendreher zwischen Flachkabel und PCB gehen und vorsichtig eine kleine Schlaufe rausziehen. Das LCD klappt nun wie von selbst gegen die PCB und kann vorsichtig (!!) am linken, oberen und unteren Rand angedrückt werden.
 Das Doppelklebeband links in voller Höhe (überdeckt die 20pol Löcher) in ca. 1cm Breite positionieren, und dann oben und unten in ca. 5mm Breite über die volle PCB Länge. Rechts kommt KEIN Klebeband hin. Es ist zu vermeiden rechts mit Kraft auf das LCD zu drücken. Dort ist es sehr empfindlich, weil dort kein Plastik-Rand darunter ist. Das Doppelklebeband links in voller Höhe (überdeckt die 20pol Löcher) in ca. 1cm Breite positionieren, und dann oben und unten in ca. 5mm Breite über die volle PCB Länge. Rechts kommt KEIN Klebeband hin. Es ist zu vermeiden rechts mit Kraft auf das LCD zu drücken. Dort ist es sehr empfindlich, weil dort kein Plastik-Rand darunter ist.
 +==== On shortening the male header J103 on OVI40 UI for LCD display ====
 +Cutting the male header pins pf J103 (on component side) is required to reduce height of the LCD Display module above OVI40 UI PCB. Cutting / shortening the pins on component side might not be the best idea as it damages the female connector each time it's inserted, due to the fact that cutting the J103 pins produces sharp edges that scratch the femaile LCD display header.
 +An alternative is to solder the pins at the right depth and then cut the pins flush to the pcb on the solder side.
  • en/ovi40build/displaybuild.txt
  • Last modified: 15.05.2018 13:18
  • by df8oe
