Differences
Both sides previous revision Previous revision | |||
en:ovi40build:batch1uiboarderrata [27.01.2018 18:45] – df9ts_user | en:ovi40build:batch1uiboarderrata [12.02.2018 11:56] (current) – df9ts | ||
Line 1: | Line 1: | ||
{{tag> | {{tag> | ||
===== Errata OVI40 UI V1.8 Batch 1 Kit ===== | ===== Errata OVI40 UI V1.8 Batch 1 Kit ===== | ||
=== In Kit Bag 1 === | === In Kit Bag 1 === | ||
* 3.5 mm miniature jacks J1, J2, J3 - plastic pins do not fit on PCB holes as they are | * 3.5 mm miniature jacks J1, J2, J3 - plastic pins do not fit on PCB holes as they are | ||
- | * get yourself the fitting jacks Lumberg 1503-7. Can be ordered e.g. at Reichelt.de, | + | * get yourself the fitting jacks Lumberg 1503-7. Can be ordered e.g. at Reichelt.de, |
* The 470 nF capacitors are delivered in size 0805, PCB layout is for 0603. They can be soldered in, but 470 nF in size 0603 are preferred in case you have them in stock or can get them easily. | * The 470 nF capacitors are delivered in size 0805, PCB layout is for 0603. They can be soldered in, but 470 nF in size 0603 are preferred in case you have them in stock or can get them easily. | ||
=== In Kit Bag 2: === | === In Kit Bag 2: === | ||
* Mini-USB socket J11 is “Type A” - this is wrong. “Type B” is mandatory to be used. Please get the correct part, e.g. Buerklin.de order number 72F2280 | * Mini-USB socket J11 is “Type A” - this is wrong. “Type B” is mandatory to be used. Please get the correct part, e.g. Buerklin.de order number 72F2280 | ||
* The CR2032 back-up battery holder needs to be modified before soldering it in. On pin needs to be shortened so it is flush with the PCB surface TOP layer, see photo | * The CR2032 back-up battery holder needs to be modified before soldering it in. On pin needs to be shortened so it is flush with the PCB surface TOP layer, see photo | ||
Line 14: | Line 17: | ||
=== In Kit Bag 4: === | === In Kit Bag 4: === | ||
- | * The 2.2 uF capacitors are provided in size 0805, PCB is layyed out for 0603. Can be soldered in. Use 0603 if you have them or can easily get them. | + | |
+ | * The 2.2 uF capacitors are provided in size 0805, PCB is layyed out for 0603. Can be soldered in. Use 0603 if you have them or can easily get them. | ||
=== In Kit Bag 5: === | === In Kit Bag 5: === | ||
=== In Kit Bag 6 === | === In Kit Bag 6 === | ||
* The capacitors (8, | * The capacitors (8, | ||
=== Other === | === Other === | ||
* R2, R6, R7, R10-12,R15, R25, R40 are delivered in size 0603, PCB layout is 0805. Can be used. | * R2, R6, R7, R10-12,R15, R25, R40 are delivered in size 0603, PCB layout is 0805. Can be used. | ||
* C100 ist marked as “COO” in schematic (letters " | * C100 ist marked as “COO” in schematic (letters " | ||
