{{tag>review}}{{tag>english}} ===== UI Board Test & Trouble Shooting ===== ==== EEPROM IC7 Pin 1 orientation ==== [{{:ovi40test:ic7_einbau.jpg?400|EEPROM IC7 position (photo DF9EH)}}] This is where the dot is printed. Also the edge of the case is slanted near the 1-4 pins. See [[http://ww1.microchip.com/downloads/en/DeviceDoc/Atmel-8828-SEEPROM-AT24CM02-Datasheet.pdf|here]] ==== Potential short cut next to battery holder ==== Also ganz wichtig: Wie auf dem Bild zu sehen unbedingt den einen Anschlußpin vor dem Einbau kürzen/abschneiden. [{{:projekte:ovi40-sdr:batt_halter.jpg?400|Potential Shortcut (photo DF9EH)}}] ==== Attention: STM32 MCU Pin1 Mark ==== The MCU seems to have two (!) pin 1 marks. Watch text orientation on MCU to find "real" pin 1. [{{:projekte:ovi40-sdr:ui-i40-cpu.jpg?400| Orientation of TXCO & MCU (photo DF9EH)}}] ==== Missing Audio out ==== In case of missing audio out: just in case, please check the SW_12V connection. This is power supply connector for Audio power amplifier stage unlike the mcHF. ==== Typical current consumption ==== Typischer Stromverbrauch: mit Display 280mA und ohne Display sind es 190mA. Die 80mA waren ohne Display direkt nach der Inbetriebnahme. ==== In case of problems to flash the MCU ==== * RTC clock crystal and TXCO are prerequisite for flash programming to work * Check correct orientation of TXCO (see photo on this page) * Check 3.3V at C95. If not present then L3 may be defective ==== LEDs too bright ==== With the kit resistors the LEDs are quite bright. DF9EH has reduced the values as follows: * R36 22k6 (D1 green) * R37 6k8 (D2 red) * R116 6k8 (D3 blue) ==== "WM8731 not detected" ==== In case you see this UHSDR error message please check +3V supply for codecs (WM8731) is ok. This +3V supply is generated on RF board. ==== MCU does not work, DFU connection / DfuSe not working also ==== First check that MCU is soldered in in correct orientation (see above "Pin 1"). In order to boot the MCU needs: * CPU clock (-> check TXCO clock) * correct reset voltage over time at boot up (-> check voltage over time, check voltage levels at reset pin of MCU) Only if thos pre-conditions are met will the MCU work with DfuSe or ST-Link/V2 and closed jumper "P6". Only after bootloader starts correctly will pin voltages for switches, LEDs and LCD be initialized to some extend., e.g. "Band+" and "Band-" switch. Also check: * Does PC recognize the OVI40 UI board connected via USB cable, as USB device in device manager? * PC USB port working? USB cable ok? * Check all MCU pins are correctly soldered and no shortcuts exist: Use a thin knife / scalpell / tweezer, go inbetween MCU pins and try to push the pins gently sideways one by one, check if all are soldered to PCB. If not the pin moves slightly. ==== USB Stick does not work ==== Please check +8V supply from Rf-Board, JP1.
