allgemeine Kategorie => UHSDR Firmware => Message started by: DF9EU on 12. December 2017, 17:07:37
Title: ARDOP Mode
Post by: DF9EU on 12. December 2017, 17:07:37
Hello Guys,
I think this would be an interesting mode.
Its now working in the WINLINK System.
Is there a possibillity to implementate like the FREEDV Mode?
https://de.wikipedia.org/wiki/ARDOP
Bernd DF9EU
Title: Re:ARDOP Mode
Post by: DD4WH on 12. December 2017, 18:17:27
Hi Bernd,
I am not quite sure what you would want to do with this mode?
Do you want the UHSDR to act like an autonomous Email-client system over the WINLINK network?
That would need a lot of work not only to implement ARDOP or some other data mode, but also to build up a protocol etc. standalone in the UHSDR software.
If you want to use your hardware for WINLINK and you use an additional computer, then the computer could do all the work and your RF hardware only does the modulation and transmitting job.
73 Frank
