allgemeine Kategorie => UHSDR Firmware => Message started by: satoryboy on 23. October 2021, 13:53:39
Title: Building Fw for H7
Post by: satoryboy on 23. October 2021, 13:53:39
Hello All
The task is simple - to compile the mod-firmware for the STM32H743ZIT6U controller (soldered from the Nucleo-144 board). There are no problems with the STM32F765ZIT6 controller, but at the time of purchase it was not available. I took a separate computer (Win7-64), installed the compilation environment strictly according to the instructions - https://github.com/df8oe/UHSDR/wiki/Windows-x64-Compiler-Setup-and-Build-Environment. Corrected only the system variable Path. Compiled the current "active-devel" project, version 2.12.0, for the H7 controller. When compiling, I got the message:
... text data bss dec hex filename
773620 6320 106256 886196 d85b4 fw-ovi40.elf
arm-none-eabi-objcopy -O binary fw-ovi40.elf fw-ovi40.bin
17:53:06 Build Finished. 0 errors, 7 warnings. (took 7m: 50s.197ms)
The firmware does not start (black screen, LEDs do not move). In this case, the stock firmware 2.12.0 starts without problems. Question - compile for Linux only? Are the instructions for her up to date?
Title: Re:Building Fw for H7
Post by: DF8OE on 23. October 2021, 14:43:37
I can only tell that compiling under Linux is working. I do not have Windows environment. What you are reporting are non-critical things, and you get a binary. If it does not work it can be related to the version of the gcc you use, or optimization settings that are set by the GUI. I do not use any GUI at all - just makefile on command line. Doing so you can be sure that there is no other hidden place whre additional settings are applied that you cannot see.
Post by: satoryboy on 23. October 2021, 18:50:12
Yes, and the executable code is more compact. But still, how do I compile a mod firmware that will not hang the controller? I will be working on a compilation option for Linux, but time is running out. Help!
Sources: https://disk.yandex.ru/d/HAfvN5SVED9GqQ
Post by: satoryboy on 24. October 2021, 09:58:51
I stitched it with an old mod-firmware compiled for Ubuntu. The transceiver works without problems. The root of all evil is in the compiler.
Post by: DF8OE on 24. October 2021, 13:19:17
Normally I am using gcc8 for building arm projects. This is a known issue and e.g. nanovna / tinysa recommends gcc8, too.. But I can use gcc-arm-none-eabi 10_2020_q4_major-1 without problems building F4/F7/H7. Resulting binary is much bigger - that's all, No other issues known.
Post by: satoryboy on 24. October 2021, 13:57:02
Thanks to the namesake from Germany, sent the firmware compiled for Linux. There are glitches and freezes, but I'll figure it out over time. The correct compiler rules.
