Title: Bootloader 4.1.1 / Firmware 2.9.43 ok?? Please confirm here!
Post by: DF8OE on 21. July 2018, 11:24:01
we are actually at the stage that we can merge H7 port of Danilo to active-devel. But we need some more reports that everything at the version of the thread title is ok.
So please report here if you have a working set and
- updating to this worked flawlessly
- you have not lost any configuration
- updates using USB stick with the new bootloader also works (you can update with the same firmware version to see if it works - if there is no error *it works*)
Reports are highly welcome. Please attach processor type (F7/F4/F4_small).
Title: Re:Bootloader 4.1.1 / Firmware 2.9.43 ok?? Please confirm here!
Post by: DL8EBD on 21. July 2018, 12:25:51
Andreas, Danilo,
an 2 Stück OV-I40 UI mit F7 getestet und keine Auffälligkeiten festgestellt.
Update läuft wie gewohnt Konfiguration scheint unverändert Update via USB Stick wie gewohnt problemlos
CPU: 32F765 |
Post by: Michael_K on 21. July 2018, 14:45:23
Hallo, an OVI40 ui1.7 Bootloader 4.1.1 und FW xxx.43 via USB-Stick update. Dabei keine Probleme Funktionen aktuell ohne erkennbare Besonderheiten vy 73 aus Erfurt Michael_K |
