Pages: [1]
Topic: how to publish informations (Read 1687 times)
positron alter Hase
Re:how to publish informations
« Reply #1 on: 19. January 2018, 08:02:36 »
Hi Andreas, I would add one topic to your listed above to think about: for contributors/developers, to mark that someone is working at particular issue (and then based on this information you can change the milestone in issues tab to "currently working"). This could be useful to prevent overlaping of work at the same code/wiki area.
Edit: Erik just now posted similar info...
« Last Edit: 19. January 2018, 08:05:11 by SP9BSL » |
df9ts
positron schon länger dabei
« Reply #2 on: 19. January 2018, 15:03:26 »
Any questions on how to use OVI40-Wiki: I can help anybody that wants to contribute in the Wiki but has open questions on how to use it.
For all others who feel more comfortable to contribute via Forum as they do now:
- I will scan the forum daily and move interesting bits to the Wiki, as I have started to do this week. The moderation of DL8EBD helps greatly both with the readability in the forum as well as the moving to Wiki (tnx, appreciated)
- There is a "discussion" field at the bottom of each Wiki page. Feel free to simply type your contributions into the discussion field as simple text in German / English / French, in case the markup language bothers you. I will move any content of discussion fields up into the pages.
As you will see when you visit the Wiki: Photos help greatly to make explanations easier to understand. So please continue to contribute Photos to the Forum, I will move them to the Wiki where applicable. Tnx to everyone for his photos so far.
BR
Gerd.
« Last Edit: 19. January 2018, 15:10:08 by df9ts » |
« Reply #3 on: 20. January 2018, 23:14:03 »
Gerd, du bist ja richtig fleißig bei der Arbeit im WIKI. Super ......
df9ts
« Reply #4 on: 21. January 2018, 12:43:21 »
Klaus,
ich sammle Infos im Wiki als "Zettelkasten". Bin ja auch OVI40 Quereinsteiger und beim Durchlesen alter Beiträge im Forum geht's mir wie Francois neulich sagte: " I started to read everything, but I am far from finished it and my reading doesn't create enough index in my mind ".
Gerd.
« Last Edit: 21. January 2018, 12:43:47 by df9ts » |
Pages: [1]
