11. April 2026, 01:39:10
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  UHSDR Firmware (Moderators: DF8OE, DL1PQ)  |  Topic: UHSDR-QRP HF-SDR mcHF (UI-Board-v.0.6.3) Modified Firmware 2.12.2_Mod1 <- zurück vorwärts ->
   Author  Topic: UHSDR-QRP HF-SDR mcHF (UI-Board-v.0.6.3) Modified Firmware 2.12.2_Mod1  (Read 3974 times)
LEO73
<Never a joy>
« on: 19. December 2024, 21:56:43 »
Hello to Every One,
EDIT
publishing the modified source code v.2.12.2 commented,
(include LCD drivers Hy28.c library)
About features:
(edited by SRM32CUBE-IDE V.1.17.0 editor-compiler)
18.Dec.2024 27Mhz opened.
For the rest,i will observe the rules and regulations on which the transceiver and project was born!
https://drive.google.com/drive/folders/1yZ-00LY_9btdKHZgZYb3FouELy-inMqe?usp=sharing
NOTE: I'm using a Sirio GPE 5/8 antenna (26-27-28Mhz).
Here C code added for modification:
radio_management.c <FILE>
Code:
static const BandInfo bi_11m_all =    { .tune = 26064000,    .size = 1930000,    .name = "11m",  BAND_MODE_11};
typedef enum
    BAND_MODE_80 = 0,
BAND_MODE_11 = 8,
} band_mode_t;
static const BandInfo *bandInfo_combined[MAX_BAND_NUM] =
&bi_11m_all,
static const BandInfo* bandInfo_region1[MAX_BAND_NUM] =
&bi_11m_all,
static const BandInfo* bandInfo_region2[MAX_BAND_NUM] =
&bi_11m_all,
static const BandInfo* bandInfo_region3[MAX_BAND_NUM] =
&bi_11m_all,
static const BandInfo* bandInfo_region3_thai[MAX_BAND_NUM] =
&bi_11m_all,
radio_management.h <FILE>
ui_menu-structure.c <FILE>
Code:
const MenuDescriptor powGroup[] =
{ MENU_POW, MENU_ITEM, CONFIG_11M_5W_ADJUST, NULL, "11m  5W PWR Adjust", UiMenuDesc("Defines the internal power adjustment factor to achieve 5W power on this band. See Adjustment and Calibration for more information.") },
{ MENU_POW, MENU_ITEM, CONFIG_11M_FULL_POWER_ADJUST, NULL, "11m  Full PWR Adjust", UiMenuDesc("Defines the internal power adjustment factor to achieve full power on this band. Check the output signal when adjusting for full power! See Adjustment and Calibration for more information.") },
ui_menu_internal.h <FILE>
Code:
enum
    MENU_DSP_NR_STRENGTH = 0,
  MAX_RADIO_CONFIG_ITEM  // Number of radio configuration menu items -
This must ALWAYS remain as the LAST item!
uhsdr_board.h <FILE>
Code:
#define MAX_BANDS              18
#define   TX_POWER_FACTOR_11_DEFAULT   0
ui_menu.c <FILE>
Code:
    case CONFIG_11M_5W_ADJUST:      // 11m 5 watt adjust
        UiDriverMenuBandPowerAdjust(var, mode, BAND_MODE_11, PA_LEVEL_HIGH, options, &clr);
        break;
    case CONFIG_10M_5W_ADJUST:      // 10m 5 watt adjust
        UiDriverMenuBandPowerAdjust(var, mode, BAND_MODE_10, PA_LEVEL_HIGH, options, &clr);
        break;
case CONFIG_11M_FULL_POWER_ADJUST:      // 11m 5 watt adjust
        UiDriverMenuBandPowerAdjust(var, mode, BAND_MODE_11, PA_LEVEL_FULL, options, &clr);
        break;
    case CONFIG_10M_FULL_POWER_ADJUST:      // 10m 5 watt adjust
        UiDriverMenuBandPowerAdjust(var, mode, BAND_MODE_10, PA_LEVEL_FULL, options, &clr);
        break;
Code:
To save this band IN EEPROM add follow 2 lines:
ui_configuration.c <FILE>
Code:
UI_C_EEPROM_BAND_5W_PF(7,12,m)
UI_C_EEPROM_BAND_5W_PF(8,11,m)  // <--
UI_C_EEPROM_BAND_5W_PF(9,10,m)
UI_C_EEPROM_BAND_FULL_PF(7,12,m)
UI_C_EEPROM_BAND_FULL_PF(8,11,m) // <--
UI_C_EEPROM_BAND_FULL_PF(9,10,m)
NEVER A JOY
[Dateianhang durch Admin gelöscht]
« Last Edit: 14. April 2025, 11:56:19 by LEO73 » Logged
Re:UHSDR-QRP HF-SDR mcHF (UI-Board-v.0.6.3) Modified Firmware 2.12.2_Mod1,open C
« Reply #1 on: 20. December 2024, 07:09:33 »
Quote from: leo73 on 19. December 2024, 21:56:43
Open to trasmit on CB frequencies (very illegal  )
Yes, so it is. You can look at the regulations of every country in the world, and you can find tons of informations in the web, for example here.
UHSDR team and me are not responsible for this "opening the door for everyone to break the laws" - so modifying the firmware in this way is in the responsibility of your own risk.
@leo73:
Please understand that we cannot host the firmware binary on our server. We do not want to support breaking laws. Feel free to put the binary somewhere else and add a link here to this file with a comment that UHSDR-team is not respopnsible for this binary.
« Last Edit: 20. December 2024, 07:16:46 by DF8OE » Logged
LEO73
<Never a joy>
« Reply #2 on: 20. December 2024, 07:47:15 »
Thank you Andreas, you did well to remove yourself from responsibility. Forgive me if I was a bit cheeky to load the code on your server.
Have a nice day.
« Last Edit: 20. December 2024, 07:47:46 by leo73 » Logged
« Reply #3 on: 20. December 2024, 07:53:05 »
Not a problem. Nothing to forgive - everything is ok now. Feel free to post a link, it will not be removed.
EDIT
Everyone is responsible for his own doing. Discussing the code is welcome and you can post code changes here. But not "ready build binaries!" There is a new EU law which will be up next time where publishers of binaries are responsible for the files. If the publisher is not accessible, the owners of the servers will be responsible. I think in times of tiktok instagram & co. this is a very wise decision. Source code is not affected.
« Last Edit: 20. December 2024, 08:02:24 by DF8OE » Logged
