29. March 2024, 09:13:48
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  UHSDR Firmware (Moderators: DF8OE, DL1PQ)  |  Topic: LCD Auto Blank <- zurück vorwärts ->
   Author  Topic: LCD Auto Blank  (Read 2038 times)
LCD Auto Blank
« on: 10. August 2020, 19:46:53 »
Hi
« Last Edit: 29. June 2022, 21:00:36 by SP3OSJ » Logged
Re:LCD Auto Blank
« Reply #1 on: 11. August 2020, 03:57:53 »
Hi Artur,
that is absolutely strange! At "auto-dark" nothing else is done than removing completely PWM voltage from LCD completely. I have tested here with my OVI40 and I cannot confirm. At the lowest illumination level consumption is ~ 1.5mA higher than at LCD completely off. That is the behaviour I expected to see. Tested with 3.5" LCD 480x320.
Re:LCD Auto Blank
« Reply #2 on: 11. August 2020, 13:25:45 »
I have checked now mcHF with linear regulators and 2.8" LCD and mcHF with switching regulators and 3.5" LCD@480x320: same result. Lowest power consumption at LCD AUTO BLANK. If I switch to lowest possible brightness current increase a few mA. Not much - but it increases on all devices under all circumstances.
Re:LCD Auto Blank
« Reply #3 on: 11. August 2020, 13:39:41 »
BTW:
The reason why we implemented AUTO-BLANK was not lowest power consumption. It was stopping the rf noise of the data traffic to the LCD which gave "helicopter sound", especially when used in SPI mode.
« Last Edit: 11. August 2020, 13:39:55 by DF8OE » Logged
Re:LCD Auto Blank
« Reply #4 on: 11. August 2020, 19:04:06 »
Dann liegt es am LCD. Aber - wie gesagt - das Ziel dieser Option ist nicht dr geringste Stromverbrauch, sondern die kleinstmöglichen HF -Störungen!
Re:LCD Auto Blank
« Reply #5 on: 12. August 2020, 11:57:34 »
@Thomas: what types of STM you have in both versions 3.5 and 4"? Are both the same?
I see in the code that during blanking feature waterfall/spectrum refresh is stopped, although not have idea if this would impact the current consumption...
Re:LCD Auto Blank
« Reply #6 on: 12. August 2020, 12:23:43 »
@Slawek
Yes. The stopping of spectrum and WF causes dramatically decrease of data traffic and so reduction of rf noise. Most other data-traffic (like S-meter) is with minor influence.
Andeas
Re:LCD Auto Blank
« Reply #7 on: 12. August 2020, 12:39:08 »
Hi Andreas,
I have some suspicion, when the scheduler for waterfall/spectrum is disabled there might be other function (like the s-meter) which takes full core power... I've observed this some time ago after menu was displayed. As said: this is only suspicion...
Re:LCD Auto Blank
« Reply #8 on: 12. August 2020, 13:15:52 »
Now I can follow your idea! You think not the LCD is consuming the power.... But that cannot be because of my both mcHF (F4) and my both OVI40 (F7/H7) do not show larger power consumption when LCD is blank. I think it is coupled to the LCD.
Re:LCD Auto Blank
« Reply #9 on: 12. August 2020, 13:35:20 »
Thank you for the explanation, I still don't have assembled the H7 version. The F7 behaves identical to yours... So, the idea fell
Re:LCD Auto Blank
« Reply #10 on: 12. August 2020, 14:19:32 »
But Arturs idea of saving power during AUTO BLANK is not so bad! Maybe there is a "power saving mode" which can be entered via command and which puts controller to "sleep mode" (suspend to RAM hihi...). We have to dig into the controllers datasheet
Re:LCD Auto Blank
« Reply #11 on: 12. August 2020, 14:25:29 »
very interesting...
Re:LCD Auto Blank
« Reply #12 on: 12. August 2020, 14:28:26 »
There are more of them...
