16. April 2024, 12:58:50
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  UHSDR Firmware (Moderators: DF8OE, DL1PQ)  |  Topic: Testers wanted / Tester gesucht <- zurück vorwärts ->
Pages: 1 2 [3] Go Down Print
   Author  Topic: Testers wanted / Tester gesucht  (Read 4739 times)
Re:Testers wanted / Tester gesucht
« Reply #30 on: 18. July 2018, 08:37:09 »
Hi Andreas,
I would say yes if you switch to the gcc7 for builds, so that we can find out if this change does not cause issues (anymore).
« Reply #31 on: 18. July 2018, 08:48:38 »
Shall I release both bootloader and firmware binaries?
« Reply #32 on: 18. July 2018, 08:55:50 »
Hi Andreas,
yes. The change to gcc7 affects both firmware and bootloader, so we should release both as experimental/development builds.
« Last Edit: 18. July 2018, 08:56:32 by DB4PLE » Logged
« Reply #33 on: 18. July 2018, 09:10:02 »
OK - done. Everything finished successfully.
Because of my script does yet not support fw and bl upgrading in one step I have done it in two.
OE5RKM
« Reply #34 on: 19. July 2018, 06:35:07 »
Hallo
zur Info
ovi40 F7 BL 4.1.0 mit Firm 2.9.42 OK
mit Firm 2.9.43 error 2
BL 4.1.1 mit Firm 2.9.43  ALLES OK
Danke
73 Rudi
Pages: 1 2 [3] Go Up Print
