11. June 2026, 03:45:47
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  UHSDR Firmware (Moderators: DF8OE, DL1PQ)  |  Topic: sparrow psk tx <- zurück vorwärts ->
   Author  Topic: sparrow psk tx  (Read 4116 times)
qrper
sparrow psk tx
« on: 08. May 2018, 07:57:31 »
hi all,
I have the Sparrow version of the radio and want to work in digital modes tx and rx
what is the procedure to accomplish this do I need an external modem etc or can it be done just using the usb connection
regards gm6jua
Re:sparrow psk tx
« Reply #1 on: 08. May 2018, 08:11:08 »
Firmware is capable to work in PSK and RTTY "standalone". If you want to do it via software (PC/laptop) you only need an USB connection. Firmware serves CAT and USB audio simultaneously via one USB connection.
qrper
Re:sparrow psk tx
« Reply #2 on: 08. May 2018, 12:57:11 »
Quote from: DF8OE on 08. May 2018, 08:11:08
many thanks Andreas,
I have hooked it up to my computer selected bpsk-U and am using ham radio deluxe on the computer but cannot get the radio to go into tx/rx should I set the rit button to show dig ext sorry for the daft questions but new to sdr qrp and usually use a kenwood ts590 sg in the shack
but I have no setup instructions for how to do this for the sparrow
73's  dave gm6jua
Re:sparrow psk tx
« Reply #3 on: 08. May 2018, 18:06:15 »
Your program should use CAT commands for RX/TX switching and frequency control.
I am only working with Linux and all my programs use CAT...
