allgemeine Kategorie => OVI40 SDR Projekt (English AND German discussions around OVI40 SDR project) => Message started by: yeson on 25. August 2022, 07:21:23
Title: Problem UI with STM32H734ZIT6
Post by: yeson on 25. August 2022, 07:21:23
Processor STM32H743ZIT6V The DFU can see in PC but the Dfuse Demo v.306 cann't Program and I check some key piont.
Power 3.3V is available.
Reset (25 foot) C94 with 57KOhm works - rises to 1.9V.
The IC5 (ASTX-H11) 3-pin provides a 16MHz signal with a 1.7V amplitude.
Title: Re:Problem UI with STM32H734ZIT6
Post by: yeson on 25. August 2022, 07:24:56
After that I programmed with ST-Link V2.
Bootloader to 0x08000000 Fireware to 0x08060000. I think to MCU cann't not run
Post by: yeson on 25. August 2022, 07:28:47
bootloader write to 0x08000000
Post by: yeson on 25. August 2022, 07:30:05
Fireware write to 0x8060000
Post by: yeson on 25. August 2022, 07:33:13
MCU core menu
Post by: yeson on 25. August 2022, 07:41:41
I try to use STM32cubePorgrammer. But it sitll not work
Post by: yeson on 25. August 2022, 07:42:56
STM32CP02
Post by: yeson on 25. August 2022, 07:44:02
STM32CP03
Post by: yeson on 25. August 2022, 07:45:06
STM32CP04
Post by: yeson on 25. August 2022, 07:46:20
STM32CP05
Post by: yeson on 25. August 2022, 07:50:41
After Programed.I Press Power.There is nothing display just a white bakground. I try to press Power + (Band+ or Band-).it cannot entry to bootroader menu. still nothing displayed.
Post by: DF8OE on 25. August 2022, 07:53:50
I have not programmed STM32 for a long time but I remember that STM32*7 sometimes have scrambled BOOT_ADD0 and BOOT_ADD1 which must be set manually with stlink. I am working on Linux console and havbe not any skills on Windows applications.
Post by: yeson on 25. August 2022, 08:03:33
In the Option bytes
BOOT_ADD0 = 0x08000000
BOOT_ADD1 = 0x1ff00000
Is it the correct address for booting?
Post by: DF8OE on 25. August 2022, 11:58:16
Pse look here (https://www.amateurfunk-sulingen.de/forum/index.php?board=18;action=search) and enter pattern "BOOT_ADD".
Post by: yeson on 26. August 2022, 01:53:19
I read the datasheet. edit the Boot address option bytes. the DFU work.
BOOT_ADD0(H) 0x0800 Boot from(H) 0x08000000
BOOT_ADD1(H) 0x1FF0 Boot from(H) 0x1FF00000
The DFU mode can Program. But MCU still not working.The Hold broad current just 50~60mA. The P6 is took off.
Mcu core pageļ¼š
Post by: DF8OE on 26. August 2022, 05:40:21
Test if MCU bootloader works (this does not depend on correctly working LCD and/or clock oscillator:
Press and hold BAND+ - button, press and hold power button. After 3...5 seconds relase BAND+ button.
If TRX is now in DFU mode (without P6 set!!!!) MCU is working.
