allgemeine Kategorie => OVI40 SDR Projekt (English AND German discussions around OVI40 SDR project) => Message started by: Co on 16. February 2019, 11:48:22
Title: Audio codec WM8731 not detected
Post by: Co on 16. February 2019, 11:48:22
Good afternoon,
When I power-on my MCHF-OVI40 i sometimes get the error message as per above. I suspect a bad solder joint. It would be helpful to know when the error message is being generated in order to limit the problem search. I suspect at start up of I2C. Is this correct?
Co
Title: Re:Audio codec WM8731 not detected
Post by: DF8OE on 16. February 2019, 12:02:46
Hi Co,
yes. The problem must be located in I2C lines to codecs or (!!) power supply of codecs.
Good luck!
Post by: f5ugq on 17. March 2019, 10:33:18
Hi all,
I got also this error at startup of my mchf/ovi40 transceiver, are you success to resolve it ?
Andreas, I found this old post https://github.com/df8oe/UHSDR/issues/961. In this post you wrote that the IC2 speed can be changed, I would like to test this, but I could't found the menu in the Configuration menu. I use the last version of the firmware, is it still possible to do this with this version ?
Regards.
73's, Stéphane, F5UGQ.
Post by: f5ugq on 30. March 2019, 11:08:50
Hi all,
for information, solved for me by the replacement of the 3v regulator KA78RM33RTF, there was no 3v but less than 1v.
