Pages: [1]
Topic: [solved] WM8731 not detected (Read 1982 times)
Paul C. H.
« on: 29. January 2018, 01:24:19 »
Dear all,
I am building my OVI40 UI board, successfully installed the CPU, LCD and boot up normally.
But I see "WM8731 not detected" even I have installed both (and also resistors bridging the serial buses, verified soldering with 10x mini microscope).
To pinpoint the problem, I want ask if the "WM8731 not detected" refers to U1 or U12?
Paul
« Last Edit: 29. January 2018, 09:37:28 by DL8EBD » |
I understand only two German words. with help of this forum, I often change from "g-e-t-l-o-s-t" to "g-e-l-ö-s-t". what in front of me was feeling of "f-u-n-k", now it is a piece of almost working "f-u-n-k"
Re:WM8731 not detected
« Reply #1 on: 29. January 2018, 04:15:06 »
Paul, here are the schematics
https://www.amateurfunk-sulingen.de/forum/attachments/UHSDR_OVI40_UI_18__sheet.pdf
I think, you test without an RF Board, right? The 3V for the codecs come from the RF board.
« Last Edit: 29. January 2018, 05:28:35 by DL8EBD » |
Paul C. H.
« Reply #2 on: 29. January 2018, 09:26:28 »
I temporarily borrowed 3V3 from UI_3V_CPU rail. Very nice design with three DC supplies of 3V3. No more error message, thanks DL8EBD.
Paul
Re:[solved] WM8731 not detected
« Reply #3 on: 29. January 2018, 09:39:00 »
super Paul!
your little problem is "gelöst"
Pages: [1]
