Title: Verständnisfrage Old School S-Meter
Post by: DL8EBD on 22. October 2017, 18:19:44
hab eine Verständnisfrage zum Old School S-Meter....
Bei mir zeigt das beim mcHF (und auch bei der I40 UI) immer S9+20, egal wie stark das Signal tatsächlich ist. Was muss man noch einstellen damit das einigermaßen richtig anzeigt?
Ich meine dass das früher mal funktioniert hat - benutzt wird bei mir allerdings schon länger das S-Meter nach dBm |
Title: Re:Verständnisfrage Old School S-Meter
Post by: S53DZ on 22. October 2017, 19:04:16
Thomas,
I think the "old school" S-meter shows the momentary logical OR function of RF input signal and the RF gain setting. So, if you set this over RF signal level you see only "RF gain" value. I think by saying this this S-meter mode is becoming more and more obsolete. The dBm display works really good.
73 Bojan |
Post by: DL8EBD on 22. October 2017, 19:17:40
Thx Bojan, that makes sense.
Post by: dg9bfc_sigi on 27. October 2017, 16:31:24
wenn ich mich nicht irre war old scool s meter mit alter agc und neues s meter mit neuer (wdsp) agc
Post by: DD4WH on 27. October 2017, 16:46:34
Hi all,
just dont use the "old school S-meter" any more, it used to produce problems and still does ;-).
Just use the S-meter setting based on dBm, its very accurate and easily understandable, because it does what an S-meter is supposed to do: measure the input signal level. (which the old school S-meter is not able to do) ;-)
I think by now we should just eliminate the old school S-meter from the software.
73 Frank
