allgemeine Kategorie => mcHF Projekt Deutsch / English (here you can discuss everything related to mcHF) => Message started by: WD8BXS on 16. November 2021, 21:56:09
Title: Dfuse demo
Post by: WD8BXS on 16. November 2021, 21:56:09
I had a computer crash, and now with my new hard drive installed, I downloaded the Dfuse Demo Pgm
I am being told that there is no driver for the STM Bootloader.
Any ideas??
tnx, Chuck
Title: Re:Dfuse demo
Post by: DF8OE on 17. November 2021, 06:52:41
Hi Chuck,
I cannot check because I am using Linux. But I remember the driver is included in the software bundle.
Post by: WD8BXS on 17. November 2021, 12:54:33
Yes, I know.
Still it does not work,
I will get a bigger hammer
Chuck
Post by: WD8BXS on 17. November 2021, 14:13:47
I can't seem to find the Dfuse for linux
Post by: DF8OE on 17. November 2021, 15:07:59
Hi Chuck,
the package is called dfu-util. If you are using an Arch based distro you can install it from the AURs. I do not know if there are packages for Debian / Red Hat based distros. If not you can build it manually from the sources.
Post by: WD8BXS on 28. November 2021, 18:56:36
Thanks to all I got it working OK
