allgemeine Kategorie => mcHF Projekt Deutsch / English (here you can discuss everything related to mcHF) => Message started by: WD8BXS on 03. November 2021, 14:31:35
Title: CW with straight key
Post by: WD8BXS on 03. November 2021, 14:31:35
Hello all,
I had never tested the Mchf with a straight key before, but now realize it can't be done.
There seems to be some sort of delay (Stays keyed) when you push the key, it sends a several millisecond dah.
Now when I put the radio into SSB mode, you can use the PTT button on the mic and no delay, the PTT can act like a Str Key.
Is there somewhere in the software to eliminate the DAH effect?
TNX, Chuck de WD8BXS
Title: Re:CW with straight key
Post by: DF8OE on 03. November 2021, 15:37:49
Have you wired the key as mentioned in the mcHF schematics to the 3.5mm stereo plug?
Post by: WD8BXS on 03. November 2021, 16:34:24
Hi Andreas,
Yes I have wired it as noted.
Chuck
Post by: WD8BXS on 03. November 2021, 20:17:18
WOW, I just tried it again and now it is working!!!!
Must have been holding my mouth wrong!!
Chuck
