12. July 2025, 01:03:54
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  mcHF Projekt Deutsch / English (here you can discuss everything related to mcHF) (Moderators: DF8OE, DL1PQ)  |  Topic: RED Digits <- zurück vorwärts ->
   Author  Topic: RED Digits  (Read 5759 times)
WD8BXS
RED Digits
« on: 03. August 2022, 15:54:53 »
Got a repair in, and I keep getting intermittent red digits.
Ver 6 latest firmware .
Any advice an where to start?
I have already gone over all the IQ solder joints.
TNX DE Chuck
Thanks,
De WD8BXS vy 73
Re:RED Digits
« Reply #1 on: 04. August 2022, 06:35:07 »
Hi Chuck,
this cannot be related to IQ soldering.
As you know, "red digits" are meaning that UHSDR got no "success" message from local oscillator chip (via I2C). Why not looking at the I2C connections, the power supply of the oscillator or the oscillator itself  ?
Good luck!
WD8BXS
Re:RED Digits
« Reply #2 on: 04. August 2022, 12:46:54 »
Hello Andreas,
I am so sorry, I DID mean the I2C connections...
I have soldered at oscillator and through the complete chain. to the MCU
Today I will attempt to see where the chain is broken when the digits go red.
TNX Chuck
Thanks,
De WD8BXS vy 73
Re:RED Digits
« Reply #3 on: 04. August 2022, 15:24:05 »
There are many possible reasons, but they all point to "bad I2C communication to LO Chip". It can be a bad connection, a wrong soldered pullup on I2C lines, a capacitor at these lines (some PCBs have pads for such a capacitor - never publish it), noisy power supplies of LO and/or STM32 or bad STM32 / LO chip.
Also try reducing I2C speed in configuration menu (if it is cranked up to the "red region")
WD8BXS
Re:RED Digits
« Reply #4 on: 05. August 2022, 23:38:05 »
Hooked up a known good UI Board, still red digits!
Replaced the oscillator, still red digits!
Not much left to check!!!
Seems like I always get the tough ones, hihi
de Chuck
Thanks,
De WD8BXS vy 73
Re:RED Digits
« Reply #5 on: 06. August 2022, 04:36:54 »
Have you checked correct placement of pullup resistors on SDA and SCL near to LO chip? I have seen some boards where there are soldered 90° wrong...
WD8BXS
Re:RED Digits
« Reply #6 on: 06. August 2022, 14:15:18 »
Yes Andreas,
That is all good.
This is an intermittent issue,  when it is working it will work for hours.
Seems to happen when you go to change bands.
de Chuck
Thanks,
De WD8BXS vy 73
Re:RED Digits
« Reply #7 on: 06. August 2022, 15:23:40 »
Try to reduce I2C-speeds in configuration menu. May be they are cranked up.
WD8BXS
Re:RED Digits
« Reply #8 on: 06. August 2022, 21:10:58 »
Thanks Andreas,
Yes I have tried that as well.
de Chuck
Thanks,
De WD8BXS vy 73
DB2OJ
Re:RED Digits
« Reply #9 on: 07. August 2022, 07:08:20 »
Hello,
I've had the same problem twice.
Both times I resoldered the solder joints of the SI751
and it worked perfectly again.
73 Manfed
DB2OJ
WD8BXS
Re:RED Digits
« Reply #10 on: 07. August 2022, 22:05:50 »
Hello Manfed,
Yes, I re-soldered it twice and also replaced it with a different one.
Got me scratching my head here, hihihi
De Chuck
WD8BXS
Thanks,
De WD8BXS vy 73
Re:RED Digits
« Reply #11 on: 08. August 2022, 04:41:57 »
It must be an issue on the RF board. You tested it with a known-good UI and the issue stays. Temperature sensor is on the same bus. It can be the cause, too.
WD8BXS
Re:RED Digits
« Reply #12 on: 08. August 2022, 23:40:11 »
Yes, I changed the temp sensor as well
Thanks,
De WD8BXS vy 73
WD8BXS
Re:RED Digits
« Reply #13 on: 09. August 2022, 22:32:41 »
Well, I think this is progress!!!
When I remove R18, the red digits go away!!
I tried replacing U11, but no luck.
Just if R18 is out...
de Chuck
Thanks,
De WD8BXS vy 73
WD8BXS
Re:RED Digits
« Reply #14 on: 10. August 2022, 17:41:16 »
The Plot thickens....
If I remove R22 and R23  the issue goes away.
If I remove R51 and R52, then replace R22 and R23 the issue returns!
What do you think about that??
de Chuck
Thanks,
De WD8BXS vy 73
