19. April 2024, 17:17:06
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  mcHF Projekt Deutsch / English (here you can discuss everything related to mcHF) (Moderators: DF8OE, DL1PQ)  |  Topic: mcHF LPF switching bug? <- zurück vorwärts ->
   Author  Topic: mcHF LPF switching bug?  (Read 1210 times)
yi3whr
I'm a llama!
« on: 20. June 2021, 08:45:04 »
referring to mcHF schematics sheet 4/8 LPF switching circuit ... there is R31-R34 which is a pull up resistors for the output of U14 the resistance of these resister are 27ohm .... that's a 180mA of current through the U14 ... is that ok ?? or I'm missing some thing ?
Re:mcHF LPF switching bug?
« Reply #1 on: 20. June 2021, 11:02:21 »
27 Ohm will draw more than 180mA, but ok for few mS pulse.
yi3whr
I'm a llama!
« Reply #2 on: 20. June 2021, 11:49:09 »
ok thank you ... just want to make sure that I got it right
any way I'm going to use regular relay ... os i will change this circuit
« Last Edit: 20. June 2021, 11:56:28 by yi3whr » Logged
« Reply #3 on: 20. June 2021, 12:42:59 »
If you mean "monostable relay" by "regular" you have to change the driver stage of the relays and you are incompatible with firmware. Firmware provides pulse switching for bistable relays.
