Pages: [1]
Topic: Problem with firmware D2.12.0 or with my mCHF? (Read 1406 times)
DL2JML
« on: 31. May 2021, 19:46:58 »
I am posting this here and on mcHF@group.io, hence the English language. Answers in German are welcome.
I just finished to build and adjust my mCHF. Using the single test tone and looking at the output with a spectrum analyser, spurious emissions are OK on the low bands, so-so on the higher bands (there is a spurious spike -12 kHz to the main signal, but at about -40dB) and not good on the 10m band. Reducing max power for that band in the PA adjust menu to about 3W improved the 10m band, but it is still not so good with spikes around the main signal when I use the single tone test signal function.
The FreeDV signal appears to be great with no spurious emissions, even on the 10m band. Output power as measured with a power meter (internal and external) is about half of what it should be, however.
I tried to transmit using SSB with a mic. Signal is OK on the lower bands (but read on) and catastrophic on 10m with 2 extra SSB transmissions left and right of the main signal.
Now for the really puzzling part: when I transmit a SSB signal, power is up to 3x what it should be. On the lower bands, I get over 15W (roughly the maximum I set in the PA output configuration menu), even when setting PA to 5W or 1W. On 10m, I still get about 7W. This is more than what I set in the PA output configuration section.
This is with firmware D2.12.0, which came with the kit. Is this a problem with that particular firmware? I don’t understand why output power can be different between SSB and FreeDV.
DL2JML
Re:Problem with firmware D2.12.0 or with my mCHF?
« Reply #2 on: 01. June 2021, 10:34:19 »
Der Antwort wurde mir von Ian MM0GYX in groups.io gegeben: CMP sollte nicht ausgeschaltet sein, sonst sendet SSB immer mit voller Leistung.
Jetzt sieht das Signal etwas besser aus. Leider merke ich auch, dass der mCHF weitere Signale ausser Band sendet und werde das PA nochmals überprüfen müssen...
DL2JML
« Reply #4 on: 01. June 2021, 19:39:08 »
Probier mal selber. Auf SSB, mit CMP auf OFF geht die Sendeleistung (bei brüllen, vielleicht...) bis zum Maximum. Mit CMP auf 0, geht die Sendeleistung bis zu was eingestellt wurde (egal, wie laut man brüllt).
DL2JML
« Reply #6 on: 02. June 2021, 11:21:58 »
Ich weiss, dass bei SSB die Sendeleistung von Eingangspegel abhängt. Ich hätte aber nicht erwartet, dass mit "CMP OFF" der Begrenzer auch ausgeschaltet wird. Mit "CMP" hätte ich lediglich Dynamikkompression erwartet.
Wie wird der Mikrophoneingang abgetastet?
DL2JML
« Reply #8 on: 03. June 2021, 16:57:42 »
Dieser "codec chip" ist ein WM8731, der einfach den Mic oder Line Eingang digitalisiert. Ich weiss aber nicht mit welchen Frequenz und Bittiefe. Klar, dass es übersteuert werden kann. Dann verstehe ich, dass der Bit Strom verzerrt wird. Wieso es zu einer Erhöhung des Ausgangspegels und nicht zu einer Verzerrung des Signals führt verstehe ich nicht. Es ist kein analoger SSB Modulator im mCHF, SSB wird rein Digital erzeugt. Oder irre ich mich?
Übrigens: meine PA Probleme haben sich weitgehend gelöst, indem ich den Bias Strom verringert habe. Danke für die Hilfe.
Pages: [1]
