29. April 2024, 12:44:04
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  mcHF Projekt Deutsch / English (here you can discuss everything related to mcHF) (Moderators: DF8OE, DL1PQ)  |  Topic: Convert .bin firmware to dfu file <- zurück vorwärts ->
   Author  Topic: Convert .bin firmware to dfu file  (Read 1323 times)
arcticsilver
I'm a llama!
« on: 27. April 2021, 17:13:56 »
Hi all,
I'm trying to convert a .bin firmware file for an OVI40 F7 (Sparrow) to a .dfu file but I don't know the 0x address to do the conversion.  Any help would be appreciated!
satoryboy
Re:Convert .bin firmware to dfu file
« Reply #1 on: 28. April 2021, 05:13:08 »
Hi
Fw upload from address 0x8010000, loader from 0x08000000. 73!
« Last Edit: 28. April 2021, 05:18:33 by satoryboy » Logged
WD8BXS
« Reply #2 on: 30. April 2021, 12:47:01 »
I wonder if when using ST-Link to load MCU STM32F437VIT6TR, should the starting address be 0x08010000 ?
Instead of 0x08000000 ??
Thanks,
Chuck
Thanks,
De WD8BXS vy 73
« Reply #3 on: 30. April 2021, 14:18:00 »
Bootloader starts at 0x08000000
Firmware starts at 0x08010000
Bootloader only uses (the first) half of the space. The second half is "virtual EEPROM" inside STM32.
« Last Edit: 30. April 2021, 14:18:17 by DF8OE » Logged
WD8BXS
« Reply #4 on: 30. April 2021, 16:40:41 »
Can't you load both at the same time, with one .bin file??
A program image?
Chuck
Thanks,
De WD8BXS vy 73
« Reply #5 on: 30. April 2021, 16:57:28 »
Nop. You would overwrite "virtual EEPROM" which contains all your personal settings (or a backup of them).
WD8BXS
« Reply #6 on: 30. April 2021, 17:40:18 »
No, I mean a blank new mcu,
Thanks,
De WD8BXS vy 73
« Reply #7 on: 01. May 2021, 04:22:07 »
For a blank new MCU you can assemble the two .bin-files to one "big" starting at 0x08000000.
But it is not simply merging the two files. You have to add 0xFFs behind the bootloader to fill the space where the virtual EEPROM resides.
« Last Edit: 01. May 2021, 05:08:42 by DF8OE » Logged
