Pages: 1 2 [3] 4
Topic: Sparrow: "Local Oscillator not detected" (Read 5429 times)
Re:Sparrow: "Local Oscillator not detected"
« Reply #30 on: 01. August 2019, 19:00:42 »
the message on boot screen is "Local Oscillator Not Detected", which was stated somewhere in this thread.
In this case of no hardware oscillator found at startup, the color of the frequency digits will always be white. So a screenshot would not be helpful, unfortunately.
« Last Edit: 01. August 2019, 19:39:01 by DB4PLE » |
« Reply #31 on: 01. August 2019, 21:15:22 »
Now I do not know who is working badly SI570. Danilo, what frequency does LCD show? Read what is written case on SI570 -> SI570BBC... SI570BCC....SI570CAC.....
You have loaded a good program: H7 processor -> program H7 Z7 processor -> program Z7
If you've checked everything, buy yourself a new SI570 CMOS (SI570CAC.....) Digikey or sdr-kits.
This is a very simple electronic circuit:
73 Artur
SI.JPG « Last Edit: 01. August 2019, 21:34:06 by SP3OSJ » |
DL6RDM
MTB-Mobil
« Reply #32 on: 02. August 2019, 05:05:43 »
Hello and thanks very much for your hints!
Here a pictures of the screen:
73,
Christian DL6RDM
DL6RDM
MTB-Mobil
« Reply #34 on: 02. August 2019, 05:48:09 »
This is the SDA Signal
73,
Christian DL6RDM
DL6RDM
MTB-Mobil
« Reply #35 on: 02. August 2019, 05:48:23 »
And SCL...
The I²C Bus connection between Si570 and Temp.Sensor is ok. I measured the resistance. The output (HF ) is also not shorted. (35kOhms)
SCL.jpg « Last Edit: 02. August 2019, 05:54:52 by DL6RDM » |
Christian DL6RDM
DL6RDM
MTB-Mobil
« Reply #38 on: 02. August 2019, 09:08:02 »
Hello Andreas,
thanks for your post. I already did that. I also soldered it with hot air, see the picture below. But unfortunately with no changes in the behavior...
73,
Christian DL6RDM
« Reply #40 on: 02. August 2019, 12:24:07 »
Hi
SI570AAC000129G !!!!!!
SI570 have someone with another tip as 000141XX?
Here is the answer. (Nota SI570)
SI570.JPG « Last Edit: 02. August 2019, 12:42:19 by SP3OSJ » |
« Reply #42 on: 02. August 2019, 15:32:18 »
yes, now that I reread the datasheet again, I figured that the actual device number to lookup is 570AAC000129DG (not 570AAC000129G), the riddle is solved. Christian ordered this:
https://www.silabs.com/TimingUtility/timing-part-number-search-results.aspx?term=570AAC000129DG
This device has 0x7F as I2C address, not the default 0x55. It is surely a hardware issue (wrong part) but also a lesson learned:
It makes sense to provide a proper BOM / schematics with a PCB. I think, we all knew that...
Of course we could fix that in the software, but it is easier to order the right Si570 part...
« Reply #43 on: 02. August 2019, 15:47:50 »
Das mit der fehlerhaften BOM kann ich eventuell erklären.... es wurde damals schon der richtige Typ empfohlen, der auch im Gerät getestet wurde...
https://www.mouser.de/ProductDetail/634-570CAC000141DG
leider war der zur Zeit der BOM-Erstellung nicht lieferbar und es wurde ein alternativer Typ empfohlen. Da hatte sich dann wohl ein Fehler eingeschlichen, den niemand bemerkte. Soweit ich erfahren habe wurde diese fehlerhafte BOM auch weitergereicht.
Das tut mir natürlich leid, aber es wurde auch immer klar darauf hingewiesen dass die BOM zwar gewissenhaft erstellt wurde, aber der Besteller die Richtigkeit zu überprüfen hat! Sie wurde schließlich erst nach dem Aufbau erstellt...
« Last Edit: 02. August 2019, 15:53:50 by DL8EBD » |
« Reply #44 on: 03. August 2019, 06:49:22 »
solche Dinge passieren halt, ich wollte UNS BASTLER nur daran erinnern, wie wichtig eine gute BOM (und Schaltplan) ist.
Das war auch damals, als ich meinen mcHF 0.4 gebaut habe, eine echte Herausforderung, das Zeug bei den diversen Lieferanten zu finden und mich zum Beispiel für den "einen" Kondensator aus dutzenden mit dem gleichen Kapazitätswert auszuwählen und zu verstehen ob ein X7R jetzt auch geht, wenn es keinen X5R gibt. Bei dem Si570 gab es zum Glück genau den auf der Liste, aber da war mir auch nicht klar, wie wichtig da die exakte Nummer ist. So richtig bewußt ist mir das erst jetzt geworden, was ich da für ein Glück hatte
Pages: 1 2 [3] 4
