Pages: [1]
Topic: [solved] V6 Behavior (Read 1508 times)
WD8BXS
« on: 05. November 2018, 17:03:47 »
I have a head scratcher here. This is a new build Version 6. it is not receiving correctly.
Here is a screen shot. There are identical signals on both sides of center. It seems like it hears the whole band at once.
I have replaced U2, U3, Q1, U15, U16 and T1
No Joy.
Normally when testing, you can touch a wire to R1, R4, Q1 collector, output of T1 etc.. and hear the noise floor come up.
On this one I lose it at the collector of Q1, I hear a click when I touch there but no noise floor.
This is why I replaced T1, U15, and U16, but again , no joy. Any ideas whould be helpful.
Thanks, Chuck WD8BXS
Thanks, De WD8BXS vy 73
WD8BXS
Re:V6 Behavior
« Reply #1 on: 05. November 2018, 17:04:45 »
I forgot to mention, It is the RF board, as it does the same thing with another UI board.
Chuck
WD8BXS
Re:V6 Behavior
« Reply #3 on: 05. November 2018, 18:48:29 »
I have good signals with a scope and frequency counter at R22 and R23
Chuck
WD8BXS
Re:V6 Behavior
« Reply #4 on: 06. November 2018, 13:46:48 »
Any chance someone could post pics of scope waveform from R22 and R23, T1 output, U16 input and outputs I and Q ??
Thanks, Chuck
WD8BXS
Re:V6 Behavior
« Reply #5 on: 07. November 2018, 15:10:36 »
ANYONE??
WD8BXS
Re:V6 Behavior
« Reply #7 on: 08. November 2018, 13:32:55 »
I think I understand, do you mean lifting R43 or R43 one at a time, then measuring pins 2 or 3 respectively on U16?
Thank, Chuck
WD8BXS
RE:[solved] V6 Behavior
« Reply #9 on: 09. November 2018, 20:10:18 »
I found a bad R49 Causing too much bias on T1
Thanks for all your help!
de Chuck 73
« Last Edit: 10. November 2018, 11:29:50 by DL8EBD » |
Pages: [1]
