Topic: STLINK AND MCHF UI BOARD (Read 1340 times)
Co
« on: 31. March 2018, 10:46:13 »
Hello,
I replaced the F407VET6 with a F407VGT6 on a V0.4 UI board. I would like to load the newest bootloader and firmware using STLINK on the STAND-ALONE UIboard (RF board not connected). The VGT6 is 'factory new'. STLINK works OK and connects to the VGT6.
Question 1 : Do I need to set any other flags in the option bytes than those already set i.e. Level 0 BOR OFF WDG set nRST-STOP set nRST-STDBY set no addresses are set.
Question 2 : What is the value of the loading adresses to set in the address field in the main window of STLINK
73's
Co
Re:STLINK AND MCHF UI BOARD
« Reply #1 on: 31. March 2018, 13:47:50 »
- Options bytes: The default values are the ones to use. If in doubt, run a chip erase, that will set everything just right. - 0x80000000 -> bootloader.bin - 0x80010000 -> firmware.bin
Co
« Reply #2 on: 31. March 2018, 19:30:15 »
Hello Danilo,
Tnx for your answer. It strikes me that the firmware address is different from the F7 in OVI40 : 0x8001000 for F4 compared to 0x8010000 in F7.
regards
Co
« Reply #3 on: 31. March 2018, 19:45:06 »
you are right, I swapped leading zero and 8 :
Bootloader 0x08000000 Firmware 0x08010000
