Topic: Bauteilsuche für OV140 UI PCB (Read 2788 times)
dl7qk
« on: 29. January 2018, 16:44:48 »
Hallo,suche ASTX-H11 16 MHz TCXO 2,5ppm 3,2 x 2,5 mm TCXO_32X25
vy 73 dl7qk
Paul C. H.
Re:Bauteilsuche für OV140 UI PCB
« Reply #1 on: 30. January 2018, 11:31:23 »
vy 73 dl7qk
I don't have TXCO too, using a cheap 32x25 non-TCXO 16MHz for testing, ordered a 50x32 TCXO from element19 as workaround. (I try to attach a photo but sometime the bbs do not load it)
Paul
I understand only two German words. with help of this forum, I often change from "g-e-t-l-o-s-t" to "g-e-l-ö-s-t". what in front of me was feeling of "f-u-n-k", now it is a piece of almost working "f-u-n-k"
« Reply #2 on: 30. January 2018, 11:37:32 »
Hi, for me worked the mcHF solution: 2063959 from Farnell. Little bigger, but fits.
Paul C. H.
Re:Bauteilsuche für OV140 UI PCB (TCXO)
« Reply #4 on: 30. January 2018, 11:59:25 »
Yes, Most of the time I verify before post, but forgot this time, ha ha ha. Previously I suspect Google translate ate the attachment.
The workaround TCXO i will try is FOX924 result not know, still on the way.
Paul C. H.
« Reply #5 on: 30. January 2018, 12:25:46 »
| Yes, I ordered exactly this TCXO. Thank you for LCD adapter layout.
dl7qk
« Reply #6 on: 30. January 2018, 14:07:23 »
ich habe den betellt-Qantek Quarzoszillator QX533A16.00000B15M SMD HCMOS 16.000 MHz 5 mm 3.2 mm 1.3 m-und hoffe,daß es klappt.
v73-dl7qk
dl7qk
« Reply #7 on: 31. January 2018, 08:33:22 »
jetzt gibt es de TCXO auch in der richtigrn Größr bei Völkner
Qantek Quarzoszillator QX333A16.00000B15M SMD HCMOS 16.000 MHz 3.2 mm 2.5 mm 1.2
v73 dl7qk
sm0nor
« Reply #9 on: 04. February 2018, 19:06:18 »
I'm wondering about the 1uF's on the errata list that are recommended to change to smaller package. Do they have to be COG types? My local supplier stocks X5R, X7R and Y5V types. 73's Ulf
