07. February 2026, 20:01:45
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  Selbstbauprojekte (Moderator: DF8OE)  |  Topic: DDC Module2 <- zurück vorwärts ->
Pages: 1 2 3 [4] Go Down Print
   Author  Topic: DDC Module2  (Read 54083 times)
DD4WH
Re:DDC Module2
« Reply #45 on: 29. September 2020, 17:05:52 »
Thanks Andreas, that really helps a lot to understand!
Best 73s,
Frank
Teensy Convolution SDR
Re:DDC Module2
« Reply #46 on: 14. October 2020, 14:44:43 »
I think these "resistors" are non-linear because of inside the FPGA you find semiconducting things. So it is dependent on the voltage which the DMM uses for measuring. Best is to put DMM in diode test mode, connect positive pole to GND and check with negative pole if you can see protection diode on the recent pins.
Werner
Re:DDC Module2
« Reply #47 on: 06. February 2021, 11:27:23 »
Hello Artur,
I am looking for a map of the assembly for the DDC Module 2.
(N7DDC DF-2020-USA)
I received the DDC Module 2 board from you.
Maybe jou can help me further?
I wish you a nice weekend and stay healthy!
Werner
Werner
Re:DDC Module2
« Reply #48 on: 07. February 2021, 12:13:45 »
Hello Artur,
You helped me a lot with your very quick info !
That is the point of a good forum, thanks for your help !
I wish you a nice weekend and good health.
vy
Werner
Re:DDC Module2
« Reply #49 on: 25. April 2021, 16:17:47 »
Hi Artur,
maybe you have swapped power values  ??
And DSP is both. I think you mean "mixing concept" instead of "DSP".
Stay healthy
« Last Edit: 25. April 2021, 16:18:38 by DF8OE » Logged
Re:DDC Module2
« Reply #50 on: 25. April 2021, 16:50:51 »
Hi Artur,
running devices "out-of-specs" is something that users who homebrew projects is standard for tens of years. But it is not without risk. I by myself use to follow the specs that are provided for an item.
Do not misunderstand:
There *are* constellations where I rely on the working of a device out of its specs.
But if there are speed grades for a device I have strong dought if it is a good idea to save some cent and rely that a device which is produced for a lower spped grade will work on x4 speed without following problems...
Re:DDC Module2
« Reply #51 on: 25. April 2021, 17:02:13 »
different speed grade chips are produced on the same silicon wafer, the real diference (grade) is set by factory test and do/not meeting the required parameters for particular chip like noise, accidential failure etc, the chips grade often depends of placement on silicon wafer. This is official, who knows what chinese do doing their clones...
Re:DDC Module2
« Reply #52 on: 25. April 2021, 17:07:58 »
Maybe in this case this is different. The chip housing is different. So not a speed test results in different classes - it is the production process itself.
But you have right: there are many and multiple things you have to check if you use a device out-of-specs. You get a better reliability if you have developed much more. It is an "instinct" that leads you
Pages: 1 2 3 [4] Go Up Print
