14. May 2024, 21:43:14
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  mcHF Projekt Deutsch / English (here you can discuss everything related to mcHF) (Moderators: DF8OE, DL1PQ)  |  Topic: UI-Board und Linux <- zurück vorwärts ->
Pages: 1 2 [3] Go Down Print
   Author  Topic: UI-Board und Linux  (Read 9131 times)
Re:UI-Board und Linux
« Reply #30 on: 10. May 2018, 14:41:00 »
Update:
I was successful in finding the sources and a real 64 bit version in the "release notes". After installing it worked flawlessly like WSJTX. So I can state that it is an Ubuntu problem.
I do not know which audio source you are using - it is recommended to use the devices which start with "plughw:"
It can (and will) differ at your working space but here the device for "Input" is named:
plughw:CARD=U40SDR,DEV=1
and for Output:
plughw:CARD=U40SDR,DEV=0
Here the output of aplay -l when OVI40 is attached:
Code:
**** Liste der Hardware-Geräte (PLAYBACK) ****
Karte 0: NVidia [HDA NVidia], Gerät 0: ALC883 Analog [ALC883 Analog]
  Sub-Geräte: 1/1
  Sub-Gerät #0: subdevice #0
Karte 0: NVidia [HDA NVidia], Gerät 1: ALC883 Digital [ALC883 Digital]
  Sub-Geräte: 1/1
Karte 2: U40SDR [USB Interface 40SDR], Gerät 0: USB Audio [USB Audio]
  Sub-Geräte: 1/1
If you are using mcHF (or sparrow) your string is "mcHF" instead off "40SDR".
Pages: 1 2 [3] Go Up Print
