Pages: 1 [2]
Topic: SSB frequency translation. (Read 2891 times)
DL2JML
Re:SSB frequency translation.
« Reply #15 on: 09. June 2021, 11:12:45 »
@satoryboy I did not say your zip if full of viruses, I said that am not going to click on an unknown zip. At least, not without some explanations as to what may be within.
The explanations I would have liked to have is that the zip contains a description of the amber project, a mcHF look-alike with (hopefully) better RF design. Or you could have pointed to your github account here: https://github.com/satoryboy
Anyway: sorry for the misunderstanding and thank you for the info about the amber project. I may come back to it if I am not satisfied by the mcHF. But for the moment, I will try to operate the TX I just built...
DL2JML
« Reply #16 on: 09. June 2021, 11:17:37 »
@DF8OE
You posted:
The amplitude of the spike is not correspondent to the TX power. I think you should test on 10m because the spike is there very powerful. switch TX power to 5W step to PA menu activate "reduce level on high bands" reduce 5W PWR adjust to minimum (3) exit PA menu now switch TX power to 0.5W Use this configuration to take a look at the spike. |
If I understand correctly, you are suggesting that I redo the measurement by lowering the transmitted signal to the lowest possible level?
satoryboy
« Reply #19 on: 09. June 2021, 17:24:22 »
Thank you for your comment. The volume of the source code is very large, I was sure that it would be enough to upload the source code with each new version. Of course, I will not delete anything, I will just add links to the source code to the archive. And I will update the list. I'll do it right now. Thanks again.
Pages: 1 [2]
